gb6049
I am looking to install a set of chain stabilizer on my 1967 model 2000 3cyl diesel. Has anyone else done this and if so how did you connect to the lower arm?
My current plan is to remove the bolt connecting the upper and lower arms and replace it with an eyebolt. Using the eyebolt, I would attach the clevis end of the stabilizer to eyebolt and attach the other end with the bolt to the bracket under the rear axle. Will this work or would I be better off drilling another hole in the lower arm to attach the eyebolt?
