somanytractors
My 660 has the 5 speed that you pull up for 1st and rev. push down for 2 and 3, down farther for 4 and 5.
In another post I was told is has a live pto via 2 stage clutch.
I have 2 problems {maybe related}
1st. I have to shut the tractor off to put the pto in gear. Clutch for tranny works fine but for pto it doesn't disengage.
2nd, the shaft that the clutch pedal is on wriggles a lot like its going to fall out of the tranny. I'm going to have to deal with this shaft problem.
So my questions.
I took the bolts out of the top of the tranny to remove the cover to get inside to see whats up with the shaft. The top still doesn't come off.
I noticed a nut on top of the shifter. Do I need to remove this nut and shifter to leave the linkage inside the tranny, or do I just need to wriggle the linkage out with it attached to the cover?
And, does this shaft have anything to do with the clutch or do both work from the same linkage that the clutch for the tranny uses?
Thanks for any help
John
So my questions.
Thanks for any help
John
