Results 41 to 50 of 50
04-13-2012, 11:48 AM #41Veteran Member
- Join Date
- Feb 2009
- Posts
- 1,027
- Location
- CA
- Tractor
- 2002 New Holland TC40S
Re: After market string trimmer head options that actually work
The Trimmer Assist w/bungee cords that I have is an over the shoulder and under the arm, bandolier style-incredibly easy to get on and off or adjust. Looking at the 4 point forestry harness pictured above the thought of NASCAR comes to mind. If I were in the forestry business I would more than likely have it in my arsenal but for my seasonal weed trimming on two properties, the lightweight basic bungee harness does more than I expected.
Let your tools do the work.
04-24-2012, 12:10 PM #42Veteran Member
- Join Date
- Feb 2009
- Posts
- 1,027
- Location
- CA
- Tractor
I've been up at my mountain property for the last five days and ran the JD string trimmer with the new PivoTrim head for around five hours working under the trees and around the granite outcroppings.
As a test, I had it loaded with two factory PivoTrim strings and two Shakespeare .105" "Ugly Line" strings, all of which were cut to 12" and then 6" laced.
All four sets went the distance without replacement and are still good to go again. The two factory string sets lost about 1/4" of length and the two Shakespeare sets were the same length as started but the end tips that were originally cut blunt became slightly pointed.
My string trimmer that has been sitting idle for a couple of years is now finally for the first time a functional piece of equipment.Let your tools do the work.
04-24-2012, 11:10 PM #43Bronze Member
- Join Date
- Aug 2011
- Posts
- 95
- Location
- Covington, Louisiana USA
- Tractor
- 1999 Bobcat 763F
Hey Nickel, glad to hear your good out come.
I received my Pivotrim last week. This is what was in the package.
Before I ordered, I called the company to make sure it would fit on my older Model 410 Snapper commercial trimmer. (About a 60cc engine, so pretty strong) They assured me it would. And, it did. It couldn't have been simpler to attach.
Used it this weekend. For the money I'm very happy with it. I gave it a good workout. Banging into at least 100 fence posts, around trees and along the concrete slab of the house. Of course the strings will eventually break. I would say it lasted 5 to 8 times longer than my original spool head. I used the same string that was in the trimmer (.095) I precut mine at 13 inches, so when looped in was 6 1/2" long. I used all four spindles. I'll try using just two of them next time to experiment next time. All in all a good deal.
Note: Their ad shows the trimmer running into a chain link fence. I don't have that to try, but I really think that may be hype. That has to be bad for any string.
04-25-2012, 12:22 PM #44Veteran Member
- Join Date
- Feb 2009
- Posts
- 1,027
- Location
- CA
- Tractor
HarryN,
Good to hear your experience was the same as mine-try some .105" line.
I think these kits would be a little less expensive if they didn't come with a heaping handfull of adaptors for all the different machines out there! I guess I should just be thankful that one of them actually fit my JD.Let your tools do the work.
04-25-2012, 02:26 PM #45Bronze Member
- Join Date
- Aug 2011
- Posts
- 95
- Location
- Tractor
- 1999 Bobcat 763F
Nickel, my thoughts exactly. As soon as I use up the .095 line, I'll go to the .105 stuff. Glad I found your post to begin with.....
04-25-2012, 03:47 PM #46Silver Member
- Join Date
- Dec 2005
- Posts
- 185
- Location
- Hurricane alley (South Louisiana)
- Tractor
- Mahindra 3510
If you like a bump feed head, try the Oregon speed feed head. Got one for my Stihl trimmer and it is by far the best head I have ever had. You load it without taking it apart by feeding the string through it then twisting the top to load. Takes about 30 seconds and lasts a good while. I have had it for 2 or 3 seasons now and never had a problem with line feeding.
04-26-2012, 12:01 AM #47Silver Member
- Join Date
- Mar 2011
- Posts
- 124
- Location
- Summit, MS
- Tractor
- Mahindra 5035, MF250, New Holland LS190, JD Gator 6x4
Ordered a Pivotrim today based on the reviews here.
Mahindra 5035 PST, MF 250, Jinma LW-8 BH, Kubota 72" ZD331, NH LS190 SS, JD 6x4 Diesel Gator, SS backhoe attachment, Markham grapple, Markham stump bucket, Markham tooth bucket (awesome), 6" Jinma chipper, 72" King Kutter tiller, 72" box blade, 72" rotary cutter, 72" landscape rake, homemade hydraulic post hole digger, homemade 16' boom, homemade pallet forks
04-28-2012, 09:38 PM #48
Kyle - CompactTractorFan
Kubota BX25 w/R4's (23 hp, 17.7 PTO hp), Loader, Backhoe, 60" Mid Mount Mower, Cyclone Rake Z-10 Lawn Vacuum, CountyLine Carryall, Ferris 48" Walk-Behind Mower, Honda 21" Walk-Behind Mower, Mighty Mac 4" Chipper/Shredder,
2000 Dodge Intrepid, 2012 Ford F-150 EcoBoost
04-28-2012, 11:03 PM #49
Picked up a Pivotrim at Northern Tool last week for $29.95. Installed in about 2 minutes, unscrew 1 bolt, unscrew the old head, screw on the Pivotrim, feed the 4 strings in. Works great on my 4 cycle trimmer.
Randy
NH Boomer 8N, 6' Squealer Rotary Cutter
NH TC40DA, 16LA FEL, Red Master II Harrow
Land Pride 6' Tiller, 7' Landscape Rake
2008 GMC 2500HD 4X4 6.6 Duramax, Allison
2003 GMC 2500HD 4X4 6.6 Duramax, Allison
Big Tex 12GP 20' GN trailer
Cub Cadet RZT 50"
05-14-2012, 08:33 PM #50Veteran Member
- Join Date
- Feb 2009
- Posts
- 1,027
- Location
- CA
- Tractor
Similar Threads
New String Trimmer
By devildog1 in forum Garden ToolsReplies: 10Last Post: 05-02-2011, 07:59 AM -
need good weed whacker / string trimmer
By Soundguy in forum Related TopicsReplies: 23Last Post: 07-19-2008, 05:46 PM -
Trimmer String
By Arcane in forum Garden ToolsReplies: 2Last Post: 10-18-2005, 04:35 PM -
how well do trimmer mowers work?
By Anonymous Poster in forum Garden ToolsReplies: 13Last Post: 05-08-2001, 01:09 PM
