Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Mar 2012
    Posts
    13
    larimore northdakota
    Farmall B
    Default Yardman starter???
    Pulling apart my mower as I've figured out that the starter **** out on me.... But I'm stuck I can't get this metal plate or what not off.... Can anyone tell me how??? Pix attached
    Attached Thumbnails Attached Thumbnails Yardman starter???-image-1407714340-jpg   Yardman starter???-image-453134815-jpg   Yardman starter???-image-3965757625-jpg
  2. #2
    Join Date
    Mar 2012
    Posts
    143
    Sydney , Australia
    Cub Cadet Gt2550
    Default Re: Yardman starter???
    Looks like a spanner for the nut and a large puller to remove the flywheel/ringgear
    My Wife said I do not listen
    At least I think thats what she said
  3. #3
    Super Member
    Join Date
    Aug 2004
    Posts
    6,770
    North of Mtl,Que,Can (Ste Adele)
    MT180D
    What generally works is to back off the nut flush with end of the threads.
    Then a sharp rap with a hammer most often the flywheel will simply pop of the tapered shaft end.
    Not to heavy a hammer and not all that hard a blow.
    You want the nut flush so as not to damage the threads.
    Good luck!
  4. #4
    Join Date
    Feb 2012
    Posts
    81
    Elizabethtown, KY
    John Deere LX255 - T0-30 - John Deere 4200 w/FEL
    I replaced my Yardman starter last year without removing the flywheel. (19 hp Briggs) It took a lot of very short turns of the wrench on that back bolt, but it can be done. Good Luck.
Similar Threads
  1. Starter problems, or what?
    By woodhook13 in forum Parts/Repairs
    Last Post: 09-25-2011, 07:25 PM
  2. Bobcat 863 starter kicking over w. ignition 'off'?
    By Stubee in forum Bobcat Construction Equipment
    Last Post: 07-13-2011, 12:34 AM
  3. Starter keeps cranking ???
    By Richard in forum Parts/Repairs
    Last Post: 02-03-2011, 08:21 PM
  4. Deere 318 starter issue
    By cef2lion in forum John Deere Lawn & Garden
    Last Post: 11-03-2009, 08:59 AM
  5. Neat starter design
    By Chuck52 in forum Parts/Repairs
    Last Post: 04-03-2004, 10:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
