Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 22
  1. #11
    J_J
    J_J is online now
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    13,652
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Default Re: Pressure washer, serviceable parts?
    I agree with RANDYT , clean or replace the unloader valve itself or parts necessary
    For those that don't know, the pressure/psi developed is determined by the nozzle utilized.
    You probably will never see the advertised pressure while using the pressure washer. If you don't believe that, insert a 3000/3500 pressure gage in series with the hose going to the gun.
    The advertised pressure is the pressure developed by the pump and the restriction used, IE, the nozzle opening, or the unloading pressure, which can be adjusted by a screw and spring. .
    After the pump is running, the unloader is closed until you release the trigger on the gun. It will recycle the water into the input and you will notice the water will get warm if done long enough.
    If the unloader is rusted or frozen, you could blow the pump, hose or gun, or the engine would just shut off.
    One way to check the unloader is to start the PW with the trigger pulled on the gun. The engine will start and pump, but as soon as you release the trigger, the engine tries to or will shut down.
    I have 4 pressure washers and have been using them for about 20 years, observing some of the problems stated. They are all Honda driven.
    A 13 HP engine can pump 6.5 GPM at about 3000 psi.
    A 2 HP engine can pump 2 GPM at about 1500 psi.
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  2. # ADS
    Advertisement
    Join Date
    Mar 1998
    TractorByNet.com
    Posts
    Register now to remove this ad.
  3. #12
    Join Date
    Nov 2008
    Posts
    534
    Covington, GA
    JD 870
    I replaced my cheap pump with an expensive (sort of) pump with a three year warranty. The pump shop said to bring it back when I have it reassembled so they can adjust the max PSI based on my engine size. I gather the pump can go higher on the PSI but the engine does not have the umph to work that hard. I could be recalling incorrectly but ...
  4. #13
    Veteran Member deepNdirt's Avatar
    Join Date
    Sep 2009
    Posts
    1,962
    Nth East Ga, USA
    yanmar YM-1700
    Quote Originally Posted by J_J View Post
    After the pump is running, the unloader is closed until you release the trigger on the gun. It will recycle the water into the input and you will notice the water will get warm is done long enough.
    This explains why I see so many variations of HP,PSI,& GPM on many of the different makes I been looking at,
    Some I see has Higher HP while has less Psi, some has Higher Gmp than hp ratings, etc,etc,
    My Karcher is 5.0 Hp, 2400 psi, with a delivery of 2.5 Gpm, I have seen some pressure washers showing 6.0 Hp. with 2200 psi and 2.4 gpm,....
    So in a sense it starts at the Pump an engine is added with the correct Hp to match the max Gpm's the pump can produce,
    As I stated, when I took the unloader out I found the lower O-ring to be chewed up, Though nothing appeared to be corroded as I might had thought, but I shot some pen oil down in the hole just in case, I also wiped off the small plunger or piston that I put the new O-ring onto, as I was examining it I noticed what look to be threads in behind the small spring, the two ends of this plunger seem to be thread together holding the spring around it, Out of curiosity would this happen to be where the pressure is adjusted? By threading this part either in or out?
    Thanks
    Never judge a man until you've walked a day in his shoes,
  5. #14
    J_J
    J_J is online now
    Join Date
    Sep 2003
    Posts
    13,652
    JACKSONVILLE, FL
    The adjusting spring nut should be readily available.
    If you install a gage in the OUT port, and plug the hose into the gage assembly, you can see the operating pressure anytime the pump is running.
    If you have a 3000 psi unit, and the trigger is off, the pressure should be relieving at about 3000 psi.
    As soon as you pull the trigger to spray, the pressure will decline and remain fairly constant as long as the trigger is pulled.
    The smaller the orifice on the tip, the closer you will get to the max pressure.
    Notice the pressure when you are using the bleach nozzle. Very low.
    A lot of people brag about their pressure washer, but they just don't know the facts.
    Another smart fact for those that use the turbo nozzles, always aim the lance down before you pull the trigger. If you don't, you slam the ceramic element against the brass head and could damage it.
    J.J.
    Git er done.
  6. #15
    Join Date
    Sep 2009
    Posts
    1,962
    Nth East Ga, USA
    yanmar YM-1700
    Again! another great explanation, I just so happen to have one of those dirt buster rotary nozzle heads, the one that looks about the size of a hand granade, It has always work good, but the last time trying to us it, it would not spin inside, I noticed it had aaparto take it appart, so I did just that and found a plastic part inside that look to have small round ball bearings on each end with holes in them, The plastic part sidewalls were joined only by a small amount of material, one apartad broken appart and must be the reason why it no longer spins, It puzzled me as to why it had broken, Buexplanationyour explination I think I done just as you mention not to do, actually while it was when I was having to remove the tips to give thinstallrt and re-instal in order to get the pressure bacIncidentallyain,
    Insodently: I priced a new dirt buster and one will cost 59.00 up, I had no idea was such expensive part, Does anyone know if that small plastic part inside the dirt buster head can be purchased?
    thanks
  7. #16
    Join Date
    Sep 2009
    Posts
    1,962
    Nth East Ga, USA
    yanmar YM-1700
    Does anyone know about this product? ( all power ) I guess because I've been doing research on pressure washer, and also because I search Tiger direct electronics, This product pop-up on their site for me to see..... the pressure washer specs look decent 3200 psi / 2.7 gpm, No engine brand or size given, only that it is a 208cc , even though the price of 299.00 is the winner , Not ever heard of the name brand, or could I find any review on it, Could this be another one of them China built stuff ?
    Attached Thumbnails Attached Thumbnails Pressure washer,   serviceable parts?-u43-1000_phcall02_js_gl_4904549.jpg   Pressure washer,   serviceable parts?-u43-1000_phcall07_js_gl_4904549.jpg
  8. #17
    J_J
    J_J is online now
    Join Date
    Sep 2003
    Posts
    13,652
    JACKSONVILLE, FL
    At 25 cc per HP, that would equate to about 8.32 HP. They usually de-tune the engines for longivity.
    Also, a pump pumping about 2.7 GPM's at 3200 psi would require at least a 6 HP motor.
    CC TO HP conversion table
    J.J.
    Git er done.
  9. #18
    J_J
    J_J is online now
    Join Date
    Sep 2003
    Posts
    13,652
    JACKSONVILLE, FL
    deepNdirt ,
    Some of the turbo nozzles have rebuild kits.
    Go to Ebay and type in turbo nozzle. They list a bunch of them.
    This is a good Pressure Washer data site.
    http://www.ultimatewasher.com/nozzle...ure-washer.htm
    J.J.
    Git er done.
  10. #19
    J_J
    J_J is online now
    Join Date
    Sep 2003
    Posts
    13,652
    JACKSONVILLE, FL
    Some more useful data.
    The unloader is similar to a relief valve on a hyd valve. Turn it right to tighten the spring, and increased the pressure.
    If you want to PW with a lower pressure, adjust the unloader by turning the nut left which will loosen the nut pressure on the spring, decreasing the pressure.
    J.J.
    Git er done.
  11. #20
    Join Date
    Sep 2009
    Posts
    1,962
    Nth East Ga, USA
    yanmar YM-1700
    Thanks to everyone for sharing your knowledge
    I cleaned up the unloader and replaced the O-rings from both pressure washer units, each now working perfectly,
    I can't help but to wonder how many folks who have none working pressure washer think the pumps have went bad, In my search for a larger commercial type washer, I've noticed many ads where people have stated the pumps will needs replaced, Would a commercial pressure washer have the same type
    (unloader) in the pump? what's the chance on rolling the dice, getting one of these and only having to change the O-rings as well?
Similar Threads
  1. pressure washer not generating pressure
    By HCJtractor in forum Parts/Repairs
    Last Post: 12-27-2011, 08:35 AM
  2. John Deere 2520 Mid PTO Power Washer, Pressure Washer
    By blackfalcon in forum Attachments
    Last Post: 11-20-2011, 06:16 PM
  3. Pressure Washer ?
    By redka in forum Attachments
    Last Post: 10-15-2011, 08:26 PM
  4. Buying Advice Pressure Washer
    By weldingisfun in forum Buying/Pricing/Comparisons
    Last Post: 08-07-2010, 08:16 AM
  5. Pressure Washer - Low Pressure
    By jgbanshee in forum Parts/Repairs
    Last Post: 04-29-2005, 12:29 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
