Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Jun 2010
    Posts
    1
    Default 3 board fence help
    Hey guys, new to posting to the forum, but been reading for a while.
    I'm putting in a 3 board vinyl fence and had a couple questions for those w/ experience:
    1. Fence co. recommends a bag of concrete per post hole--I was thinking maybe just doing crete on corners and gate posts and just tamping soil on line posts--bad move?
    2. I want to install vinyl-coated mesh on the inside to keep kids and a small dog (30lb) inside the fence--fence co. says they have nylon clips that hold the mesh and screw into vinyl, but they dry out and break in a couple years--any better ideas for attaching it or making it look good--also, is it possible/necessary to stretch the mesh before attaching it? Either way, I'm going to cut sections for each section of fence as opposed to wrapping over the rear side of posts.
    thanks for any pointers!
  2. #2
    Platinum Member mustangsallysdad's Avatar
    Join Date
    Jan 2010
    Posts
    559
    Default Re: 3 board fence help
    Use the cement...it's more about stability than anchoring. Not much weight to the vinyl and a stiff gust of wind as well as freeze and thaw cycles will wreak havoc on it. That's been my experience.
  3. #3
    Join Date
    Aug 2005
    Posts
    1,491
    Guernsey Co. Ohio
    Ford 3000, JD 2550
    A properly tamped post will be just as solid as one set in concrete, and frost heave can happen either way. However, setting in concrete is faster and MUCH easier on the shoulders.
Similar Threads
  1. Deer Fence Design
    By nate_m in forum Projects
    Last Post: 03-17-2008, 11:29 AM
  2. How to set fence along slope? Tips/tricks?
    By hazmat in forum Rural Living
    Last Post: 06-19-2007, 10:59 AM
  3. Fence Post Spacing
    By DTCOOPER in forum Projects
    Last Post: 08-12-2005, 12:11 PM
  4. Yet Another Fence Question: Keeping in the dogs.
    By dmccarty in forum Projects
    Last Post: 04-09-2005, 01:28 AM
  5. 3 Board Black Border Fence
    By crown in forum Rural Living
    Last Post: 04-05-2002, 05:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
