Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Join Date
    Nov 2010
    Posts
    111
    Webster, NY
    John Deere GT245
    Default Poly vs. Steel lawn roller
    I'm trying to decide between a new Brinly poly lawn roller ($140) vs. a used Agri-Fab steel lawn roller ($110, in good condition). Both would be 24" x 36" rollers, so would be approximately the same weight when filled with water.
    Suggestions?
  2. #2
    Super Member
    Join Date
    Dec 2007
    Posts
    9,721
    Central Ohio
    JD 5520, 790- Kub L4300, B7800, MX5100, M7040
    Default Re: Poly vs. Steel lawn roller
    I have used both and like poly better because I can turn sharper corners without digging in.
    Some steel may work that way as well but I don't know about that.
    I have a couple Brinley products and they are quality and well made.
    My lawn rake from them is really nice.
    May I be the kind of person my dogs think I am,
  3. #3
    Join Date
    Nov 2010
    Posts
    111
    Webster, NY
    John Deere GT245
    Quote Originally Posted by sixdogs View Post
    OK, thanks. What are the dimensions of the roller you use? My thought is that the 24x36" might be most effective because it's heavy and narrow, so it's putting its weight down on a smaller area than the wider rollers.
  4. #4
    Super Member
    Join Date
    Dec 2007
    Posts
    9,721
    Central Ohio
    Quote Originally Posted by sgoldste01 View Post
    Mine is 24" diameter and 48" wide. It is not as nice as I would like in that, even at 1000 lbs, it's not enough unless the ground is soggy.
    I also have a 6' wide Brillion seeder and I'm going to try pulling that over the grass on the belief the notched wheels will move the dirt around more.
    Rollers are not fully satisfying unless you start with a fairly smooth lawn to begin with but that's my opinion.
    I like the idea if narrower for more concentrated weight but you need more input from an actual user.
  5. #5
    Join Date
    Nov 2010
    Posts
    111
    Webster, NY
    John Deere GT245
    I was only the Brinly web site, and didn't see a lawn rake. Are you refering to the dethatcher? I'd be interested in a product that I can use in the fall to collect leaves; I'd prefer not to buy the bagger attachment for my GT245 (that I bought used, but is new to me), but maybe that's my best option.
  6. #6
    Super Member
    Join Date
    Dec 2007
    Posts
    9,721
    Central Ohio
    Duh--oops--I meant lawn sweeper. The drier and fluffier the grass or whatever, the easier it picks it up. It does not pick up dog doo.
    Brinly-Hardy Brinly 42 in. Lawn Sweeper, STS-42LXH
    Brinly-Hardy Lawn Sweeper 42in., Model# STS-42LXH | Lawn Sweepers | Northern Tool + Equipment
    I noticed their sweeper was exactly the same as the green John Deere one and figured if good enough for them it was likely good enough for me.
    It works beautifully and here is a thread that I posted using it and showing the pile of grass raked.
    http://www.tractorbynet.com/forums/p...lawn-good.html
  7. #7
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    17,911
    Central Ohio
    Kubota MX5100
    Diameter is what determines the ground compaction, NOT width. A 36" wide roller @ 24" diameter is going to have the exact SAME compaction as a 60" wide roller of the same diameter.
    Larger diameters get greater compaction because of added weight. But NOT larger widths. So if you want the MOST compaction you can get, get the largest diameter you can.
    We made one 38" diameter out of 1/8" steel. Very heavy duty. It weighs more empty than most 24" do filled. AND we can add ~1850lbs of water. It is only a 48" roller as well
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  8. #8
    Join Date
    Nov 2010
    Posts
    111
    Webster, NY
    John Deere GT245
    I think we're saying the same thing, although I wasn't being clear. What I meant is that the 36" wide x 24" diameter roller will provide better compaction than a 36" wide x 18" diameter roller, or even a 42" wide x 18" diameter roller, due to the extra weight pressing on the 36" wide contact area.
  9. #9
    Join Date
    Apr 2008
    Posts
    17,911
    Central Ohio
    Kubota MX5100
    You got it
    Length dont mean squat as far as compaction. It's all in the diameter.
    Enjoy
    Attached Thumbnails Attached Thumbnails Poly vs. Steel lawn roller-mar29_0009-jpg
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  10. #10
    Join Date
    Nov 2010
    Posts
    111
    Webster, NY
    John Deere GT245
    Do you have any idea how well the sweeper works compared to the tractor bagger attachment? Does it pick up as well? Does it hold a similar volume? I'm mainly interested in leaf pick-up, rather than grass....
Similar Threads
  1. Lawn roller...
    By mrcaptainbob in forum Build-It Yourself
    Last Post: 08-25-2010, 01:54 PM
  2. where to buy a 5' lawn roller?
    By Mosey in forum Attachments
    Last Post: 05-08-2003, 04:04 PM
  3. Lawn Roller
    By bpence in forum Attachments
    Last Post: 04-11-2002, 11:03 PM
  4. Homemade Lawn Roller, how heavy should it be?
    By Anonymous Poster in forum Attachments
    Last Post: 03-02-2002, 09:43 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
