Results 1 to 10 of 10
  1. #1
    New Member
    Join Date
    Sep 2012
    Posts
    2
    Glade Spring, VA
    John Deere 245
    Default nrw member - looking for a recommendation for zero turn mower that is good on slopes
    Hello, I am interested in recommendations for a zero turn mower. I have about two acres to mow, some of it is pretty steep. I currently have a JD series 200 mower and it barely stays upright on the slopes. I have heard that zero turns can be even more prone to slipping or rolling over than the standard yard tractors. I have looked at some zero turn Cub Cadets with a steering wheel. The salesman said that this would be a good choice. Does anyone have any experience with these zero turn mowers or any advice
  2. #2
    Super Member Scooby074's Avatar
    Join Date
    Aug 2006
    Posts
    6,565
    Nova Scotia
    BX 25, ZD 326
    Default Re: nrw member - looking for a recommendation for zero turn mower that is good on sl
    What kind of angle are we talking? ZT , particularly homeowner grade ones arent the best on slopes. Some commercial grade units are pretty good, like Scag.
    I regularly mowed 20+ degree slopes with my x540 deere. I now mow those same slopes with a BX25.
    How much money do you have to spend?
  3. #3
    Elite Member Briana03's Avatar
    Join Date
    Jul 2010
    Posts
    3,292
    San Diego, California
    None
    Welcome to TBN
    I moved your thread to the General Lawn & Garden forum.
    Briana
    TBN Support
  4. #4
    New Member
    Join Date
    Sep 2012
    Posts
    2
    Glade Spring, VA
    John Deere 245
    I can spend 4-6 thousand for a mower. Does anyone know does a steering wheel (as is available on the Cub Cadet) make it any easier to mow a bank? I currently can (barely) mow this bank with my series 2000 John Deere conventional yard tractor. I really don't know how to meaasure the angle of the slope, just that I feel the JD is on the edge of turning over.
  5. #5
    Join Date
    Aug 2006
    Posts
    6,565
    Nova Scotia
    BX 25, ZD 326
    Id say the conventional sticks on a ZT would make it easier to feather the controls to maintain control on hills if they really are that steep
    One major issue with consumer zt is the lack of brakes. and on real steep hills you can slide and loose directional control (remember you have no steering wheels, if you loose rear grip, you have no control. The front casters are just along for the ride)
    You have enough budget to look at a x540. It really is great on slopes. The Differential lock is truly worth it, it makes a huge difference. Its a big machine but probably the best mower Ive ever used, and handles my slopes with ease.
    To measure angles, take a 4' 2x4 and lay it on the slope. Then get an angle gauge (available at any hardware store or Harbor Freight) and you can read the angle . Under 10 bucks. nrw member  - looking for a recommendation for zero turn mower that is good on slopes-dial_gauge_angle_finder_1-jpg
    Many people over estimate the slope they are facing, when you have actual measurements it makes all the difference in getting a correct recommendation.
  6. #6
    Silver Member djdicetn's Avatar
    Join Date
    Sep 2012
    Posts
    184
    Mt. Juliet, TN
    2012 Gravely Pro Turn 152
    Quote Originally Posted by rgs76 View Post
    rgs76,
    I may be a little biased because I just purchased a Gravely Pro-Turn 152 XDZ Commercial ZTR, but check out the YouTube video(and some related Gravely Channel videos available on the same page) at the link below. Looks like these ZTR's are "designed" with a low center of gravity and extra width tha makes them pretty good on slopes.
    (HD) Gravely Zero Turn Hill Climbing by Robs Mowers Alstonville - YouTube
  7. #7
    Join Date
    Nov 2005
    Posts
    2,339
    Casey County, Kentucky
    Check out these all terrain mowers.Not sure how well they work or how they hurt the wallet but they look like they would handle those slopes that take your breath away.
  8. #8
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,465
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    Quote Originally Posted by QRTRHRS View Post
    Bet the price will take your breath away. While these were interesting mowers they appear to be fairly high profile and depend on hydraulics to level them out. Most low profile (lcg) machines will slide down a slope if steep enough. What is to prevent these mower from doing the same? I know in my locale that it is very doubtful that these machines could grip the ground enough to operate anywhere near 34 degrees as they advertize.
  9. #9
    Join Date
    Sep 2010
    Posts
    235
    South Texas
    Kubota B2650 with cab
    I have had a kubota ZD 1800 for several years now and could not be more pleased. I have the 54" deck and cut 1 acre regurlarly and sometimes also a 17 acre pasture . The little diesel is great on fuel and develops lots of torques for excellent blade speed.
  10. #10
    Super Star Member
    Join Date
    Apr 2002
    Posts
    10,030
    Northern Virginia
    Kubota ZTR and RTV
    Quote Originally Posted by check 6 View Post
    When you cut the pasture, how long does it take you?
Similar Threads
  1. Need Recommendation for good hill tractor
    By wv joe in forum Buying/Pricing/Comparisons
    Last Post: 02-28-2009, 07:20 PM
  2. recommendation for a good tractor
    By mechanic in forum Projects
    Last Post: 04-24-2008, 01:48 AM
  3. Earthforce EF-4 (IR) good on slopes?
    By whiterabbit in forum All Other Brands
    Last Post: 12-10-2006, 04:38 PM
  4. What is a good zero turn mower?
    By Matt0285 in forum General Lawn & Garden
    Last Post: 09-15-2004, 09:05 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
