Anonymous Poster
- Joined
- Sep 27, 2005
- Messages
- 0
I know this has been discussed at length.... But. I've taken a look in the archives and could not find the answer I'm looking for. I have a BX22 that I don't plan to mow with. The tractor is too big for the obstructions in my 2 acres of grass, and the ride is uncomfortable at speed. This is grass, not lawn.
I have a gas 17hp Kohler twin hydro garden tractor with a 42" deck. I am tired of sniffing fumes for hours every time I mow. The ride isn't bad until I drop a rear wheel in a dip. Then the tractor lurches to the side so hard it hurts my back (the BX does the same). I don't ever pick up my clippings. I'd like to stop scalping my grass where the ground is uneaven. I don't entend to do anything else with this but mow. I have apples planted on a slight slope (10 degrees) to mow around. I would like a zero turn mower but from what I read I could not mow around the trees on the hillside. I have to go across because of the way they are planted. I don't have heavy grass to mow for the most part and would like a deck wider then 42". If I have to spend more then $3000 I'll keep the mower I have. Anything spring to mind?
