Wheelbarrow Tires
   / Wheelbarrow Tires #1
Kubotafan
Gold Member
Nova Scotia, Canada
G1800AWS, B3030HSDCC, L3540HSTCC, JD710A
I have a wheelbarrow and since new the tires keep loosing air. Is there a simple solution or should I just put tubes in them?
   / Wheelbarrow Tires #2
Either a tube or I have had good success with slime. You can get it most anywhere.
http://www.slime.com
   / Wheelbarrow Tires #3
It probably only goes flat on the bottom, so just put that on the top and you should be okay. :D
......or try a can of fix-a-flat. Why not?
But first, check that it's not leaking from the valve first (the ol' spit test). Or blow tire up , flip it over and put some soap water on the treads and around the bead. Leaking air will blow bubbles, and there's your problem. This is a good way to find if the tire picked up a nail, or is leaking around the rim, etc...
   / Wheelbarrow Tires #4
Tubes for me. Easier than finding and fixing the leak.
   / Wheelbarrow Tires #5
Put Slime in it. You'll never have to worry about it again.
   / Wheelbarrow Tires #6
A tubeless wheelbarrow tyre? Are you sure ? Never seen one of those myself, although I haven't bought a new wheelbarrow for years. Everything I have with small/narrowl wheels has tubes.
That said, I wouldn't waste time with slime in a small wheel. Put in a tube.
   / Wheelbarrow Tires #7
buy a solid tire -- no air needed -- TSC sells 'em.
   / Wheelbarrow Tires #9
That's what I did, and have never regretted it. Got tired of fixing flats here where Locust and Osage Orange make a lot of thorns. The solid tire doesn't not ride as nice as the air filled tire in my estimation. But now that I have a FEL, the wheelbarrow isn't used that much...thank goodness.
40' CONTAINER (A51244)
Wolverine Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A53421)
Wolverine Single...
ALTO AMERICAN LINCOLN MPV-60 RIDER SWEEPER (A51406)
ALTO AMERICAN...
HarbinGer V3 Plus Towable Light Tower (A52377)
HarbinGer V3 Plus...
2008 New Holland B110 MFWD Loader Backhoe (A55218)
2008 New Holland...
JLG 1255 Telehandler (A55218)
JLG 1255...
