kebo
Elite Member
- Joined
- May 16, 2006
- Messages
- 2,910
- Location
- Lexington, SC
- Tractor
- 2001 John Deere 790 4x4, bar tires
I was using my TroyBilt pressure washer back in the summer (July 4th weekend) and best as I can recall it was running fine, when I shut it off. Recently I tried to fire it up and the pull rope was REALLY hard to pull, couldn't even get the engine to spin up fast enough to crank it had so much compression. Couldn't tell right off if the pump was the problem, or if it was the motor so I pulled the plug on it, which was the easiest thing to do.
With the plug out, I can pull the starter rope very easy and spin the engine over fast. I also noticed that it spit some motor oil out of the plug hole too. I know, not good. Put the plug back in and all of a sudden, it became hard to pull again. Seems like it is getting hydrolock with the oil getting in the combustion chamber somehow? I will admit I'm not much of a mechanic so if this is something that will require going into the engine, it might be better to buy a new engine. The pump that is on it now was just recently replaced last year so I know it's in great shape and pumps just fine. But, what is the most likely problem here?
