Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Veteran Member FOURTEEN's Avatar
    Join Date
    Jan 2004
    Posts
    1,028
    Efland - Triangle of North Carolina.
    2004 Power Trac PT-425
    Default $5.oo Hustler Fastrac Air Suspension Seat
    <font color="red">
    I love my new Hustler Fastrac 52/20, but the ride was too firm! After trying various solutions I have installed an inexpensive, heavy duty, and very comfortable Air Suspension Seat. You can too!
    At the local TSC store buy a 10” Pneumatic (4.10/3.50-4) Tire/Wheel Combo With Steel Hub (TSC#3551979) for less than $5.oo.
    Deflate the tube inside the tire.
    Remove and discard the wheel and hub.
    Inflate the tube inside the tire to 1~4 psi. The tire protects and reinforces the tube.
    Remove and discard the two hold down bolts from the rear seat frame.
    Tilt the seat forward.
    Position the tire with the rear of the tire on the cross member and the front of the tire on the rear of the battery.
    Use a TyRap cable tie around the rear of the tire and the cross member to hold the tire in position.
    Tilt the seat back. (Most of the operator’s weight is on the cross member.)
    With the seat empty, the rear seat frame is about 2” above the cross member. With my 210# on the seat, the rear seat frame is about 1-1/4” above the cross member. During mowing over rough ground the space will vary from 2” to about 1/2”, but the seat frame will not bounce up off the tire, or bottom out on the cross member. Adjust the tire pressure to suit the weight of the operator.
    Air is better than springs, pads, or cushions because with only slight movements the ride is very soft and compliant, while larger movements are progressively resisted by the compression of the air.
    </font>
    [img]/forums/images/graemlins/cool.gif[/img]
  2. #2
    Veteran Member Spiffy's Avatar
    Join Date
    Apr 2005
    Posts
    1,179
    SD
    PT2445; several ag machines and classics
    Default Re: $5.oo Hustler Fastrac Air Suspension Seat
    Neat solution Fourteen! [img]/forums/images/graemlins/cool.gif[/img]
  3. #3
    Veteran Member Nasty135's Avatar
    Join Date
    Jan 2004
    Posts
    1,421
    Southern Md.
    massey ferguson 135/1433v
    I------ like it!! [img]/forums/images/graemlins/cool.gif[/img] I'll look into that for my Z also because the adjustable seat wasn't an option on my mower and I'm sure it will make a noteable difference... Thanks for the tip [img]/forums/images/graemlins/wink.gif[/img]
  4. #4
    Join Date
    Sep 2005
    Posts
    22
    Within 30 miles of Nashville
    John Deere LT110, Hustler FasTrak
    Great Idea. I will try it (as soon as the grass starts growing again).
  5. #5
    Join Date
    Jan 2004
    Posts
    1,028
    <font color="red"> I have been using my $5.oo Hustler Fastrac Air Suspension Seat for several months now. It work great with a softer smoother ride and no problems whatsoever! AND, you can't beat the price!!</font>
  6. #6
    Join Date
    Jan 2004
    Posts
    1,028
  7. #7
    Super Member
    Join Date
    Oct 2003
    Posts
    7,344
    Northeast, Ohio
    TC-40D SS New Holland
    It's gonna cost me 10 bucks, as a member of my family (I won't say who) is a bit wider in the beam and I'm afraid will require two. [img]/forums/images/graemlins/crazy.gif[/img]
  8. #8
    Super Member
    Join Date
    Oct 2003
    Posts
    7,344
    Northeast, Ohio
  9. #9
    Gold Member TwinWillows's Avatar
    Join Date
    Jan 2005
    Posts
    413
    WKY near Bardwell
    NH TC40DA
    I think that should work on my Dixie Chopper too!
  10. #10
    Join Date
    Jan 2005
    Posts
    413
    WKY near Bardwell
    NH TC40DA
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
