Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Jul 2006
    Posts
    6
    Default Attachments for zero turn mowers
    When I started thinking about getting a zero turn mower instead of a traditional tractor I quickly realized that the only drawback that I could find was that a zero turn would not accept my dethatcher and spreader attachments.
    When I got the mower I noticed that there are two preexisting holes that I assume are for a bagger. I still wanted to use my attachments that I already have.
    I had an attachment made that would allow me to use my old attachments. I realize that I will have to be careful while pulling the dethatcher so that I don't jackknife but I will be glad to have the functionality back.
    The attachment is upside-down in the pictures BTW I have a ZRT 42. I will post pictures with it attached to the mower once I get the peice from the guy that made it for me.
    http://photos.msn.com/Slideshow/View...24%26index%3d1
    The device is made up of two pieces. The first is a back plate that is 12" wide and made of 1/4" thick steel. It has two threaded rods protruding up that will fit through the two preexisting holes in the tractor.
    The second piece fits over the threaded rods and the nuts hold them together. I made the back plate so large so that it would give some strength to the sheet metal of the tractors rear plate.
    I didn't really look for very long but I didn't find anything like it out there. I thought that you would like to see what I had made.
    Attached Images Attached Images
  2. #2
    Join Date
    Oct 2004
    Posts
    1,401
    Georgia
    Default Re: Attachments for zero turn mowers
    What is a ZRT 42?
    GreenSouth Equipment
    14 locations throughout FL, GA, & SC
    www.greensouth.com
    www.greensouthused.com
  3. #3
    New Member
    Join Date
    Jul 2006
    Posts
    6
    Cub Cadet zero turn mower.
  4. #4
    Join Date
    Oct 2004
    Posts
    1,401
    Georgia
    Then it is a RZT, not ZTR...be carefull when pulling anything with this mower as the hydro's were never intended to pull attachments also be aware it is very easily to flip and attachment with a zero turn.
    www.greensouth.com
  5. #5
    New Member
    Join Date
    Jul 2006
    Posts
    6
    Thanks for the advice. I don't plan on pulling anything heavier than my dethatcher and my spreader. I only have one small hill on the side of my house and will only go down that hill with the attachments.
    Thanks again for helping a newbie.
    Dave
  6. #6
    Member
    Join Date
    Jun 2006
    Posts
    48
    South Dakota
    John Deere F930 front mower. Toro commerical mower etc. Farmall H (sold)
    Check out JRCO.
    http://www.jrcoinc.com/
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
