Paint and tires look good. Hard to tell about the rest. You can tell a lot about a cub by how tight the steering is as this was a "weak link" on that model. If the steering is tight, hydraulic works well, clutch is good, brakes work, has good oil pressure, good compression on all (4) cylinders, runs smooth, and starts well on a 6 volt battery, then I would ask around $2500 as a starting price. Beware of 12 volt conversions as this was done a lot to ease starting on a worn engine with low compression. If it still starts good on 6 volts then there probably is not even a need to check the compression. Drop the price about $250 each for the potential problems I mentioned. If it has none of these problems and he will take $2000, send me a pm and I will drive over there this weekend and pick it up. I have owned one of these quite a while and it is the "ultimate" cultivating tractor in my opinion. Mine has most of the problems I mentioned (steering, brakes, 12 volt, clutch) plus the tires are wore out and the paint looks like heck so that would be a sweet deal for me.
