Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
  1. #21
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: Ferguson TO-20,30 Hydraulics
    Hmm.. I don't have ma manual with me.. post what the description is for the 12/13.. i know one is just a retaining ring..
    soundguy
  2. #22
    Platinum Member Lazy's Avatar
    Join Date
    Dec 2003
    Posts
    516
    Missouri
    ford 1920 w/fel and bh, case 470, allis chalmers B 1937, JD 450 track loader, Case vac, 3 cub cadets ford lgt 125, Kubota 2230/60 inch mower.1948 farmall cub 1953 farmall cub
    Hard work pays off in the future. Laziness pays off now.
  3. #23
    Join Date
    Dec 2003
    Posts
    516
    Missouri
    12 ......181 162 M91 ........Drive Assembly, Valve
    13 .......195 788 M1 .........Ring, Snap, Drive Retaining
  4. #24
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    I'm guessing that part is likely to stay in the pump.. I don't see it seperately in any for sale lists.. etc.
    is your part like that damaged?
    soundguy
  5. #25
    Join Date
    Dec 2003
    Posts
    516
    Missouri
    post 19 is a pic of the assembly out of our pump. The rod is somewhat bent and distorted. but seems to slide in the pump freely, so it might be ok.
  6. #26
    Join Date
    Dec 2003
    Posts
    516
    Missouri
    The part is attached to the control valve held in place by the snap ring, so it comes out with the valve.
  7. #27
    Join Date
    Dec 2003
    Posts
    516
    Missouri
    Here is a page from the manual, might shed some light on it
    Attached Thumbnails Attached Thumbnails Ferguson TO-20,30 Hydraulics-ferrguson-hyd-pump-jpg
  8. #28
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    My point was that it is removeable.. IE the snap ring.. I only see the outter parts for sale.. not the inner parts.
    soundguy
  9. #29
    Bronze Member buckeyepost's Avatar
    Join Date
    Feb 2009
    Posts
    53
    central Ohio
    I was talking to a mechanic the other day that has worked on older Fergies and Fords for 40 years and he told me that if I'm going to change the tranny/hydraulic/diff fluid to use high trans. He said it's not as thick and well work better in colder conditions.
    He also gave me 15-40 for the motor oil, what are you all using?
    2015 Kubota BX2670 w/ 60"belly mower and FEL
    1985 Kubota B8200 w/ 60" belly mower *SOLD*
    1951 Ferguson TO-20 w/ 60" Woods finish mower *SOLD*
  10. #30
    Join Date
    Dec 2003
    Posts
    516
    Missouri
    Hey buckey
    we were using the general purpose hydraulic oil we use in our other equipment, but now we are going to use the GL-1 90 weight oil. We haven't put everything back together yet, hope to get that done in the next week or so. thanks for passing along that info.
    Charlie.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
