Results 1 to 1 of 1
  1. #1
    Gold Member
    Join Date
    Jul 2002
    Posts
    321
    West
    JD 60, 3020, 2030, 2240, 2640, Farmall A
    Default Vintage equipment Q- Transmix by The Carlson Co
    I'm sure that this is out of place.... but not sure where to put it (other then the implement section...found a old posting on one, but 0 replies). This is kind of 'vintage' and I'm sure the folks who browse here prob. knows a bit more about it or may know where to find.
    I just bought an older 3pt hitch PTO cement mixer, a "Transmix" by THE CARLSON COMPANY. Any how, I'm trying to find more info on it. Specifically if I'm missing an brackets. I figured out what two of the brackets are for that were just inside the drum. But not sure of anything else.
    I've seen older pics of the Transmix when it was build by the original company. They were made to fit specific tractors at the time- since there was no standardization yet I would say.
    We tried to hook it up to JD 2240 (not too vintage). But we found out that the front part of the mixer hits the tires- wheel spacing isn't quite enough. The 3pt lower pins look adjustable, but the next position I don't think will provide enough clearance. The 2240 tractor we tried to mount it on was a orchard vineyard model, not a standard.
    I thought about making some brackets to bring out the lower 3pt pins so it clears the tires. Center link is mounted on the unit, so it would have to be lengthened also.....
    So, any ideas if it is missing anything? The blank hole on one of the top arms, I know that's where the brackets left inside the drum go. It mounts, I think, to the bottom frame on those blank/empty holes in the back.
    I Googled "TRANSMIX" and found some old posts on other threads. Some people posted vinage manuals, but they are 'older'- the mixers that fit only one brand of tractor. This is one of the 'newer' models.
    Attached Thumbnails Attached Thumbnails Vintage equipment Q- Transmix by The Carlson Co-113-b.jpg   Vintage equipment Q- Transmix by The Carlson Co-113-.jpg   Vintage equipment Q- Transmix by The Carlson Co-113-c.jpg
Similar Threads
  1. McGee Farm Equipment - McCormick Dealer
    By Muhammad in forum McCormick
    Last Post: 06-28-2012, 06:03 PM
  2. Equipment Needed to Renovate Pastures
    By Billy_S in forum Owning/Operating
    Last Post: 05-31-2011, 09:03 PM
  3. Equipment Needed for 80 Acres
    By OrangeGuy in forum Buying/Pricing/Comparisons
    Last Post: 05-09-2007, 05:20 PM
  4. Transport of Equipment in Dump Trailers
    By Dougster in forum Trailers & Transportation
    Last Post: 05-02-2007, 10:06 PM
  5. Townline Equipment...
    By Thomas in forum Related Topics
    Last Post: 04-14-2007, 03:51 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
