Results 1 to 8 of 8
  1. #1
    New Member
    Join Date
    Jan 2012
    Posts
    1
    Belarus 250AS
    Default Belarus 250AS
    I have a Belarus 250AS with two 6volt batteries wired in series to get 12volts.
    Since one of the batteries is bad would changing to one 12volt battery be a problem?
  2. #2
    Administrator
    Join Date
    Mar 1998
    Posts
    9,051
    San Diego, CA
    None currently
    Default
    Welcome to TBN.
    Muhammad Chishti
    Administrator
  3. #3
    Member colinc's Avatar
    Join Date
    Sep 2011
    Posts
    31
    Nova Scotia, Canada
    1983 Deutz 6206 & 1952 Massey Harris 23
    Default
    Quote Originally Posted by packrat1944
    That should be ok.
  4. #4
    Super Star Member
    Join Date
    Jul 2011
    Posts
    10,432
    Yanceyville, North Carolina
    Kubota L4400
    Default Re: Belarus 250AS
    Welcome aboard.
    The PUPIL who does not surpass his Master, fails his Master.
  5. #5
    Platinum Member jpm1's Avatar
    Join Date
    Feb 2008
    Posts
    510
    Panther Lake, Oswego County New York
    Mahindra 2810 HST, Kioti DK35SE HST
    Welcome packrat1944! Years ago i had 2 Belarus 400's They originally had 6 volt batteries. The Belarus dealer i bought the tractors from changed it to 2 12volt batteries. No problems and had a lot more cranking amps. John
    Attached Thumbnails Attached Thumbnails Belarus 250AS-belarus-tractor-pictures-april-2006   Belarus 250AS-belarus-tractor-pictures-april-2006
    Lord, Help me to be the man my dog thinks i am . . .John. Mahindra 2810HST, 108H loader with Quick tach buckets and forks. Kioti DK35SE HST with loader, Hyd. top link and second set of rear remotes, 60" and 66" buckets, Kubota 900 RTV and a bunch of other good stuff
    Buy more equipment, It makes life easier.!
  6. #6
    Bronze Member nike's Avatar
    Join Date
    Feb 2011
    Posts
    93
    Ontraio
    Belarus 255
    I have a 250as and it has one twelve volt battery. The advantage of having 2 6 volt batteries is that the amps will add up, giving you 12,volts with i.e. (if you have 500 cold cranking amps, on each of these 6 volts batteries, you end up with 1000 cold cranking amps) good to know when you are selecting your 12 volt battery/.
  7. #7
    Administrator
    Join Date
    Jul 2010
    Posts
    2,138
    San Diego, California
    None
    WELCOME to TBN
    I moved your thread to the Vintage Tractors Forum.
  8. #8
    Join Date
    Aug 2004
    Posts
    1,442
    Caldwell Co. NC
    2006 Kama554; 92 Belarus 250AS
    2006 Kama 554, 92 Belarus 250AS, Bombardier Outlander Max 400.
Similar Threads
  1. battery cable for Belarus 250AS
    By mikey1306 in forum Parts/Repairs
    Last Post: 05-04-2011, 09:38 AM
  2. FEL pictures for 250AS Belarus
    By nike in forum Attachments
    Last Post: 04-04-2011, 10:18 PM
  3. Belarus 250AS
    By mikenov54 in forum Buying/Pricing/Comparisons
    Last Post: 03-17-2011, 05:08 PM
  4. Bought a Belarus 250AS
    By sataylor in forum All Other Brands
    Last Post: 05-25-2010, 09:34 AM
  5. BELARUS 250AS
    By Gizmo36 in forum Buying/Pricing/Comparisons
    Last Post: 01-22-2008, 10:48 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
