Results 1 to 5 of 5
  1. #1
    New Member
    Join Date
    Mar 2012
    Posts
    2
    Martinsburg, PA
    David Bradley Super 5 HP Special
    Default Any way to gear down/slow down David Bradley tractor?
    Any help would be greatly appreciated. I have a David Bradley 5HP Special garden tractor. When the clutch is engaged it LURCHES forward and the travel speed seems too fast. It makes plowing, harrowing, etc., very difficult because it is hard to keep up to the pace of the machine. The clutch is either "engaged" or "not engaged", there is no way to partially engage the clutch. I was wondering if replacing one of the gears would help to slow down the ground speed? I am not aware that this model of DB tractor had a speed changer. It does have a reverser. Thanks for any help on this; if I could slow this thing down a little, it would be much more pleasurable to use.
  2. #2
    Join Date
    Jan 2010
    Posts
    147
    Katrine Ontario Canada
    U 25 Super Series Mini Excavator, Kubota B2320, Kubota L3400 HST with FEL and QA forks, Kubota RTV 500
    Default Re: Any way to gear down/slow down David Bradley tractor?
    Had a David Bradley about twenty five years ago and it was old then. Cannot remember if it was belt or gear driven, but to slow the tractor the engine gear should be smaller and or the driven gear should be larger
  3. #3
    Elite Member
    Join Date
    Jul 2007
    Posts
    3,304
    The orignal David Bradley had an engine pully with two different grooves on it. One of the grooves was for a higher ground speed and the other one was for a lower ground speed. If yours doesn't have this pulley, you can find a different pulley to change the speed a bit.
    The later David Bradleys had a variable speed pully arrangement on them that allowed a pretty wide ground speed variation.
  4. #4
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    smaller tires..
  5. #5
    Elite Member
    Join Date
    Jan 2009
    Posts
    3,155
    Carroll, Ohio
    IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
    If you could find a donor model with the complete speed reducer, you could mount it on yours. They simply clamp to the frame, between the engine mount, and differential. I say complete, as the lever and rod, that activates the pulley mechanism mounts on the left handlebar, so as to change on the go.
    I've got a Special 5 myself. Never had any problems when cultivating to just creep when plants were small. It pulls along great at just off idle.
    I also have a rare '55 model Deluxe Super 3, with Continental AU85 engine. It was only made for 6 months. I've included a picture of the speed reducer pulley mechanism. If you enlarge the picture, you can see where it clamps to the frame.
    Note the tires, they are the original Allstate tires from Sears. My Special 5 also has a set on it. No checking, or weather cracks, on either one.
    Here is a link to a David Bradley reference guide. David Bradley Reference guide Find the number on the differential case on yours, then look for that number on this page. There are even pages from the Sears Farm Catalog, with the DB tractors, and attachments for the year you choose.
    I actually have 10 more over at the homeplace. Picked them up over the years for spare parts. Pretty neat little tractors, and just the ticket to cultivate in a large garden.
    Attached Thumbnails Attached Thumbnails Any way to gear down/slow down David Bradley tractor?-david-bradley-deluxe-super-3-a
Similar Threads
  1. Help! First tractor - Deere vs Kubota vs New Holland
    By Metropolis_488 in forum Buying/Pricing/Comparisons
    Last Post: 11-21-2011, 12:47 PM
  2. Yanmar Specifications
    By pennwalk in forum Yanmar
    Last Post: 10-05-2011, 02:38 AM
  3. Garden Tractor For Hills That Won't Slip - Hydro or Gear?
    By Jeeters in forum General Lawn & Garden
    Last Post: 07-14-2007, 06:51 PM
  4. eBay/Craigslist ebay item
    By djg in forum Yanmar
    Last Post: 06-24-2005, 09:37 AM
  5. JD 4000 series wheel bolts
    By Anonymous Poster in forum John Deere Owning/Operating
    Last Post: 04-13-2002, 11:56 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
