Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 28
  1. #11
    Elite Member
    Join Date
    Jan 2009
    Posts
    3,151
    Carroll, Ohio
    IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
    Default Re: Case 730 restoration
    Saw a 930 Case Wheatland, no cab, in the local Craigslist last night for $2900. Says it runs well. Over 7,000 hrs. on it...
  2. #12
    Bronze Member jonathco's Avatar
    Join Date
    Jul 2012
    Posts
    83
    Genesee, MI
    1972 John Deere 110, 1973 Sears ST16, 1984 John Deere 750
    Nice looking project you have there
    Jonathco
    John Deere 110 (1972)
    Sears ST16 w/ 3 point hitch, moldboard plow, disc, and a front snow plow (1973)
    John Deere D130 (2012)
    "If at first you don't succeed, keeping on sucking until you do succeed. "
  3. #13
    Elite Member
    Join Date
    Sep 2010
    Posts
    4,100
    CANADA
    Many
    Default
    Deereman75, you must be busy working on the tractor and forgot to give us some updates and photos.
  4. #14
    Veteran Member deereman75's Avatar
    Join Date
    Apr 2011
    Posts
    1,754
    canada
    1946 cockshutt 60
    I will get some up today, after the water dries up. I actually had to get a new pressure washer, as the old one was shot. Some of that grease just won't go... After at least 3 scrubbing with tsp, it a very, very strong mix, and at least 5 power washings with an industrial degreaser, followed by a rinse with the turbo nozzle, there is still some little bits left. I just finished the final washing, so once the tractor dries, I will go and get that gallon of varsol from the barn... Seeing as I don't have my sand blaster here, I just sanded and brushed all the loose rust and paint off. I have a few rattle cans of rust primer to put on any bare metal or rust I can't remove. My plan is to have the priming done today, and do the final prep (masking ect) in the morning, and get the first coat on the body done tomorrow. If it seems like a while between updates, it is likely something like the storms that seem to happen every second day here preventing me from getting anything done. I will be sure to update twice and today, once after final cleaning, and once after priming. (assuming I have enough primer) stay tuned, I will hopefully update in a few hours
    Never carry gasoline in your car trunk. If you do, atleast use some sort of container.
    -red green
  5. #15
    Join Date
    Apr 2011
    Posts
    1,754
    canada
    1946 cockshutt 60
    Okay, here it is. First of all even varsol wouldn't remove that gunk, I am sure it has to be a stain on the casting, as nothing will get it off. So I got the outside of the cab primed, then I ran out of primer. I will have to go into town tomorrow, and get a few more cans.Case 730 restoration-img_00000024-jpg
    -red green
  6. #16
    Elite Member
    Join Date
    Sep 2010
    Posts
    4,100
    CANADA
    Many
    Default
    Quote Originally Posted by deereman75
    Okay, here it is. First of all even varsol wouldn't remove that gunk, I am sure it has to be a stain on the casting, as nothing will get it off. So I got the outside of the cab primed, then I ran out of primer. I will have to go into town tomorrow, and get a few more cans.<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=277012"/>
    Did you try some of that Gunk Engine Bright or Simple Grean or Formula 88 for the gunk removal. I have had great succsess with all them.
  7. #17
    Join Date
    Apr 2011
    Posts
    1,754
    canada
    1946 cockshutt 60
    Simple green is what I was using with the power washer, it was amazing on everything else. I will have to see if I can find a can of gunk or carb cleaner, they are the only things I find work better then varsol.
    -red green
  8. #18
    Elite Member
    Join Date
    Sep 2010
    Posts
    4,100
    CANADA
    Many
    Default
    Another way to remove the bulk of the crap fast is to use a puddy scrapper then use the washer and solvent.
  9. #19
    Join Date
    Apr 2011
    Posts
    1,754
    canada
    1946 cockshutt 60
    Well another long overdue update, I am going to finish tomorrow at the latest. I just have the finish coat on the body left. I have been taking pictures, I will upload them all at once.
    -red green
  10. #20
    Elite Member
    Join Date
    Sep 2010
    Posts
    4,100
    CANADA
    Many
    Quote Originally Posted by deereman75 View Post
    Finally. Do you have all the decals for it or did you mask of the ones that were on there.
Similar Threads
  1. 730 ford loader
    By peahauler in forum Hydraulics
    Last Post: 04-27-2013, 12:21 PM
  2. CASE 730, who wants to see it
    By deereman75 in forum General Vintage Tractors
    Last Post: 08-03-2012, 11:58 PM
  3. Re:Case930/730 loaders
    By Donben1 in forum Attachments
    Last Post: 04-21-2012, 02:13 PM
  4. Loader Ford 730 Loader
    By Larry454 in forum New Holland Owning/Operating
    Last Post: 10-21-2011, 12:10 PM
  5. Case 222 Restoration
    By Ariena in forum Case-IH
    Last Post: 10-09-2011, 10:45 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
