Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
  1. #21
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,657
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: Seized motor AC wd-45
    atf plus a solvent is a good unsticker. I unstuck some valves in my ford 4000 after they stuck and mad artwork out of some pus rods.
    in my case.. atf and some acetone.. plus a lil diesel...
  2. #22
    Platinum Member Loadstar's Avatar
    Join Date
    Mar 2012
    Posts
    764
    Evansville, IN
    Ford 640
    Default
    Quote Originally Posted by Soundguy
    I am kinda hoping to have something to test the ATF and acetone on. Have been hearing a lot of good things about it. Not that I'm complaining the pb+kroil made it unseize so fast I didn't get to try.
    I'm ready for Saturday. Would love to try to start the wd45 that was locked. (aim high right) painted carb for it tonight.
    The cub hood/tank is in my driveway stinking to high heaven. No time to clean tank this week yet. Maybe tomorrow night I can start. Really dreading this tank.
  3. #23
    Super Star Member jerrybob's Avatar
    Join Date
    Mar 2010
    Posts
    18,785
    Somewhere in Washington
    yanmar 186D....JD LT180....DR Brush Cutter
    Quote Originally Posted by Loadstar View Post
    The ATF and acetone works great.....used it last week removing bolts from a 1954 crawler we're working on. Used ATF and Turpentine (ran out of acetone) today on a 6ft hinge that hadn't moved for years. Worked great.....give it a try. Good luck!
    Most of the stuff people worry about.......ain't never gonna happen anyway!
    Tacocat spelled backwards is Tacocat
  4. #24
    Join Date
    Mar 2002
    Posts
    52,657
    Central florida
    can't wait to see more of the wd.
    I'd like to get on e one day... that and a crawler.. and..
  5. #25
    Join Date
    Mar 2012
    Posts
    764
    Evansville, IN
    Ford 640
    Default
    Put oil filter on wd45 filled with oil and mmo(wanted to try it) Put carb on and hooked it up. Cleaned fuel bowl and screen then flushed line. Tossed battery in and finally got to crank it over. Let if puke ATF out of cylinders, tossed plugs in, turned on key, rolled over, and no spark. Picked up new 6v coil, points, and condenser on the way home.
    Last night I plugged cub tank and dumped a gal of laq thinner in it. Looked at it when I got home and it's coming along.
    Starting to get impatient may return this afternoon.
  6. #26
    Join Date
    Mar 2002
    Posts
    52,657
    Central florida
    fun bringing them back ain't it!
    keep the updates coming.
  7. #27
    Join Date
    Mar 2012
    Posts
    764
    Evansville, IN
    Ford 640
    Default
    Forgot to add pulled hood and valve cover again. Everything looking good and oiling well.
  8. #28
    Join Date
    Mar 2012
    Posts
    764
    Evansville, IN
    Ford 640
    Default
    It's fun, but I need to hear something run!
  9. #29
    Join Date
    Mar 2002
    Posts
    52,657
    Central florida
    even better when the top end is immediatly happy!
  10. #30
    Join Date
    Mar 2012
    Posts
    764
    Evansville, IN
    Ford 640
    Default
    My chief mechanic making sure I did it right haha. I like all the AC parts that were on it.
    Attached Thumbnails Attached Thumbnails Seized motor AC wd-45-image-3502236651-jpg   Seized motor AC wd-45-image-1145931756-jpg
Similar Threads
  1. Seized engine? Need some advice.
    By Kernopelli in forum Parts/Repairs
    Last Post: 02-08-2016, 12:14 AM
  2. Seized engine Rex
    By Gittyup in forum General Lawn & Garden
    Last Post: 12-25-2012, 11:09 PM
  3. Tractor News I think my 1610D seized!!!!
    By Acre Garden in forum Yanmar
    Last Post: 03-15-2012, 01:26 PM
  4. Echo weed whacker motor seized??
    By pashworth in forum Garden Tools
    Last Post: 05-14-2009, 01:37 PM
  5. Tiller tiller seized
    By case685 in forum Attachments
    Last Post: 12-14-2007, 12:06 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
