Were did you get that Blade for the loader?? I was thinking of getting one for the front of the tractor itself or a snow bucket,but if the angle plow is about the same price for the loader i will get that you can really stack snow.
JD the blade was bought from an ebay company - Quick Attach. I paid about $2400 including adding the skid shoes, wing kit, and shipping so they came down in price a little.
As far as function - there seems to be two camps on FEL vs frame mounted blades. I've only used the fel mounted blades so I am not a good source for comparisons. Here's what I've found after about 8 hours pushing snow on both gravel, pavement, flat, and uneven surfaces.
The good -
1. Easy to hookup, take off, etc.
2. Optional Wings are great and take 30 seconds to fold forward and lock in place when you want them.
3. Stacking snow is fast and easy if you have a limited amount of space to put it.
4. Blade seems to be made very well and is a quality piece of equipment.
The bad -
1. Using the skid shoes work great on pavement but make for a little rougher ride on gravel lots.
2. One of my lots is a gravel self storage business with a lot of different levels or grades as each unit drops to a slightly different elevation. Makes keeping the blade at the desired height and not digging difficult, even with skid shoes and float.
3. Even using the float position, the blade can still cause some steering issues on slopes where the front end wants to slide. You have to lift the blade slightly to get the weight back on the front wheels. Not a big deal after you get used to running the blade without float, just a little learning curve.
4. Torquing the loader arms is my only concern. I caught a hidden curve at a good rate of speed, and even with trip springs knocked my can of soda out of the cup holder and gave the tractor and cab one heck of a jolt. Didn't torque the loader or cause any damage which surprised me given the amount of force I hit it with. Just be carefully in unfamiliar areas.
Other Observations
1. The blade with the FEL quickattach really sits out front a good amount.
2. Due to the blade weight of 640#'s and how far it sits out front, loaded rear tires even with a heavy rear blade on back is probably a must.
3. 84" is probably the biggest blade I would put on this tractor, however it handles it with ease and is really a beast pushing snow.
4. Overall very happy so far, driveways can be cleared in minutes, just wishing I had a little more snow to use it.
