GaryBDavis
Gold Member
I re-furbished a used overhead diesel tank that I purchsed for $60. The stand was a little beat up, so I built a new one. The tank itself was dirty inside, but almost no rust. I replaced all the fittings, hose and nozzel.
To clean the tank out, I used a hose nozzel followed by a custom made spray nozzel to get 360 degree coverage. They were hooked up to the hot water outlet. I then plumbed my 175cfm air compressor into the tank and blew it dry. Between the hot water and the hot air from the compressor, it was clean and dry as a bone when I was done.
The only thing I wish I had done different was use teflon tape instead of recto-seal for the pipe threads. Some of that stuff will come loose and wash through, I'm sure. Hopefully the filter will catch any from the tank fitting and the rest I think dried well enough.
I put 10 gallons in it to check for leaks and all everything looks good. I'll get some diesel delivered this coming week.
