carpenter383
I've been playing with the draft control on my kioti while yard boxing. So far I've found it is GREAT for smoothing dirt and gravel! I set the top link in the middle hole on the tractor set the box level and the draft at about "6" (which is about in the middle on my tractor) and the position lever all the way down. It follows the ground very nicely and dosen't gouge in when the tractor goes through a dip. It takes a min. to figure out where to set it, but those of you who haven't tried this should give it a shot! .......A good starting point is to lower the box to the ground then move the draft lever up till just before it starts to raise the box. (Basically just take the slack out of the pins)
