As others have said take it apart and clean it up. That Clutch looks like one I had on an old Ford 5 foot mower a few years back. I think the clutch adjustment is between the yoke and the clutch disc and pressure plate adjusted with a large hex nut or spanner nut. If I am not mistaken it has a bellville spring for pressure. I usually mark the clutch disc and pressure plate and yoke and start with the cluch very loose cut a few seconds with the intent of making it slip. Remark for alignment tighten it a little cut a few seconds check the alignments of marks proceed until it doesnt slip on the heaviest stuff that your rotary can safely cut. It has worked for me and it protects the tractor from damage. More detailed pictures would help on whether that is how it is adjusted or not.
Thanks.This is one of those situations though, that while I understand every word in your post, I'm not sure what it all means! (Not that I'm criticizing your helpful suggestion, just that I"m an idiot. This must be what it feels like when I"m explaining net present value and cash flow to one of my clients).
I just don't have a sense for what "slipping" looks like/feels like.
I did manage to get a hold of someone at Hardee. He told me the following:
1. most of the cutters they sell don't come with either shear bolts or slip clutches. (Although I noticed on their web page that shear bolts come standard with many of the mowers). I asked him if this meant that people added them later and he said no, they run them without either, and he has been himself for years. (not suggesting this is correct, just that this is what he said).
He agrees with both Greg and Soundguy that there is a good chance it is frozen. To adjust it/unfreeze it (?) he said I should do the following :
1. remove the 4 bolts on the flange which holds the clutch in place.
2. remove the e clip on the front.
3. loosen the large nut on the back . He said the nut holds everything in place.
4. Retighten.
He didn't say anything about mowing first, or how much to retighten, but he might have just figured I understood that was needed.
p.s. he said if it were his he would just go ahead and mow with it as is!
