Steep gravel driveway advice
   / Steep gravel driveway advice #1
scoutcub
Ohio
Yanmar LX4900//Cub 7532//Cub Yanmar SC2400//Komatsu D38//Cub Volunteer//Cub SZ60/CAT 289C/CAT 308
Thought it was going to be in the budget for a hard surfaces driveway this year, but as it's going most likely not. Many other projects eating up $$$$.
So, with either blacktop or concrete driveway in mind for the future, (leaning towards blacktop) what kind of gravel should I use for a 180' fairly steep driveway? Concrete contractor was here yesterday, says he uses #57. (under concrete) My concerns are traction in the winter, especially for the wife & kids.
Just #57 alone, or can I add a "filler" on top to make a good surface for traction/plowing this winter?
I've read a few threads on the recycled asphalt and am interested, could I use this over gravel now, and then blacktop over it next year? Same type of gravel for either concrete or blacktop?
Long ago I was at a gentleman's house buying a mower, and he had a perfectly packed, groomed, level gravel driveway.....might as well have been asphalt as nice as it was. He told me the mix he did to get it, but of course I've forgotten those details now....
Will also have a landing to the existing garage & future garage at the top of the driveway, fairly level.
Any and all input is appreciated....I can provide pics if it will help. TIA!
   / Steep gravel driveway advice #2
57 limestone. Limestone will lock together. Will give good traction until it ices over in Winter. Do not use river and do not use slag on hills. If drive has a southern exposure you're better off. Good luck. We have about 1/2 mile of hilly drive to maintain and it's a constant battle.
   / Steep gravel driveway advice #3
Around here on a steep drive I have always had the best luck with crusher run, called road base in some areas. The stone dust helps lock it together and hold it on the hill as long as the road drains well. When I have tried #57 it tends to migrate down hill with time.
MarkV
   / Steep gravel driveway advice #5
My steep driveway is also done with road base. But it's so steep that 2 wheel drive cars have to get a running start to climb it. If they go slow or stop part way up then they can't get going again. Most visitors just gas it and dig holes, then backup and get a running start. I then have to use my 8' wide by 12' long chain link fence to flatten it. The fence digs up all sort of rocks and makes it almost worse.
   / Steep gravel driveway advice #6
The "classic" solution is to make is less steep by cutting across the face of the hill instead of straight up. Any possibility of a switchback of sorts? We have a neighbor with steep drive and they simply hate it every winter...
Mike
   / Steep gravel driveway advice #7
Here's the driveway..............
   / Steep gravel driveway advice #8
Good base of Crusher Run to start. wait a month or so, get it well packed and then add the Ashphalt Gridings on top.
if you already have a good base, just go with the Grindings
   / Steep gravel driveway advice #9
Here's ours..............Topsoil was stripped, shale base added, 57 limestone topping, ditch on uphill side with rip rap....................
   / Steep gravel driveway advice #10
Jim that ditch is a thing of beauty great views also. Looks like you were dealing with runoff from above more than anything. As far as the drive, that isn't near as steep as what I was dealing with. There reaches a point that whatever gravel you use if it is steep enough concrete is the only thing that will stand the test of time.
MarkV
