barbqranch
My TC29D has started overheating lately after 15 minutes or so of brush hogging. After starting temperature gauge rises normally to green range. Then, it will often cycle up and down an eighth inch or so for a while, then keep raising to red, at which point I drive back in. Checked radiator (when cold, at 2000 rpm) and no bubbles. Front of radiator mostly clear, liquid full. Changed water pump a year ago, no overheating till recently.
Air filter canister has a rubber intake nozzle that extends over radiator. It is partly collapsed going over radiator, and I am wondering if this might be the problem, and is there any problem with removing the "over the radiator" extension to see if that helps.
Haven't changed the air filter yet, will do so soon. It looks pretty much clean.
Thanks.
Thanks.
