GeneralEclectic
Member
- Joined
- Jun 21, 2011
- Messages
- 37
Hiya folks. Here's an update on my (new) K46CR: We had the bizarre Northeast Halloween Snowstorm here last year. Electricity out for almost a week, trees destroyed everywhere, including some on my property. After things settled down and the tree guys were here to take down the (4) ruined trees, we gave the Husqvarna YTH24V42LS quite a workout. First by pulling a 500lb log splitter around the property, and then by carting thousands of pounds of split logs uphill/downhill to the spots where they were to be stacked. Needless to say, it was kind of abusive to the K46. We hauled a LOT of wood, 300-400lb at a time.
Anyway, now the trans has about 40 hours of hard run time on it, so I wanted to switch it over to synthetic oil. For this I chose Amsoil 15W-50 Racing Oil. Why? Because it has 100% fully synthetic base stock and a huge package of friction modifiers. The latter is why this isn't approved for street usage -- there's too high a probability of damage to cats. But for a hydro, this is exactly what you want -- high stability under extreme pressure. Look at the 4-ball wear test --just what you want for use in a hydro.
It was easy to drain the factory fill out the "vent" opening. Just over 2Q. came out. There was an visible "sparkle" to the oil, presumably from very tiny particles of aluminum since ferrous particles would have been captured by the magnets. While I have no quantitative data on oil condition, qualitatively, I was glad to get that stuff out of there.
I had little trouble purging the air. About 15 seconds of operation with the freewheel engaged, and then 15 seconds with it in normal position did the trick. The trans works great now. Subjectively (and yes, I realize that The Placebo Effect may be operative) it pulls just a bit stronger with slightly less whine. Objectively, it runs cooler. After a very tough mowing session, the trans was cool enough to hold your hand on it without any discomfort.
Based on what I saw in that 40-hour oil, I can't imagine following the "no replacement" advice. Their 50-250-450-.... recommendation is much closer to reality, whether it's for commercial or homeowner use.
