OP
Verticaltrx
- Joined
- Dec 30, 2009
- Messages
- 1,908
- Location
- VA
- Tractor
- Kubota B3200/L2501/SVL65-2/U35-4, IH 454/656, Ford NAA, Case 1845C/480E/450C LGP
Thanks for the responses. As to the trailer, the reason I got an 8K trailer (just bought it last year) is so I could use it for hauling equipment as well as materials and supplies. With a light load my Toyota 4runner can pull it (like a few hundred pounds of lumber, etc). My plan is to add a second larger trailer later, maybe a 14K gooseneck, or go straight for a 15-20 ton pintle hitch trailer and dump truck.
Right now my business is kind of in the stage between needing lighter easy to haul equipment (that which could be hauled with a 3/4ton truck and 8K trailer) and the heavy yellow iron which would need a pintle hitch trailer and a tandem dump. Maybe I need to reassess where things are going and what I really need. My thought was to buy something now that could be used on both the farm and job site to get the most for my money. Maybe I should be looking at less expensive used stuff till I get it figured out. Part of my problem is my needs are fairly diverse and budget is relatively small. Good info though keep it coming.
