clemsonfor
Super Member
Maybe i ought to delete my post and you never be caught cutting a stump flush, and not letting the wife read this thread. haha!Maybe, but then how would I justify owning a backhoe attachment?
Obed
Obed
Srs good job. I drilled a hole in the end of one of my forks so I can drop a ball in it anytime I need it. Also, I put a receiver hitch in the top center of the boxblade. With top and tilt it makes it real easy to back up and hook onto a trailer.
Yes, an awesome deal, thanks. No, I didn't try to collapse one. Now that I have transported them home, I don't need to collapse them. The only thing that will make the pallet cages more attractive to the wife is when I fill them with firewood. She loves sitting next to the warm fireplace (and so do I).Obed good deal on the cages eh? So have you tried to collapse one yet? So I rekon some day they will need a coat of paint and that will make them much more attractive to the wife
I filled 3 pallet cages with wood I cut from our log pile. I wonder if I will be able to cut and stack the wood from all the logs before they rot. All the logs in the pile are off the ground except a few of those showing in the front of the picture. Otherwise, the logs are stacked on perpendicular oriented logs lying on the ground.
MotorSeven said:I see a lot of hardwood in there...yes they will last a long time off the ground. Just keep whittling away at them, no worries. Even punky wood will burn once dried out and I have a mantra....."if it fit's in the stove, I burn it".
