whistlepig
Elite Member
Good luck with your fence. Sounds like you are going to the trouble of doing it right. Well put up fence is a lot of work but if done right it is well worth the effort.
Got a couple more here...If you have the time I would enjoy some more photos of your fencing project.
Thanks for posting. Looks like some tall fence and tall posts. How tall are they?
We tried several ways of speeding up the process. Along the way we discovered we could NOT drill more than 3 holes before we dropped the posts as the dirt from the hole began to firm up (kinda turned to hard pack). As long as we drilled 3 and dropped we were good to go - but if we went 5 holes before tramping in the posts it actually slowed us down. Also helped to push the flags down to the ground along the line so we could drive over them to the next one (we used little marker flags like the ones the phone company uses to mark underground lines). We also discovered that loading more than 3 posts on the pallet forks proved unwieldy. With only 3 posts on the forks I could drop one off the end by tilting without much issue - but with five on it seemed I always had 2 roll off. The trick of course is to roll them off right at the hole so all you have to do is stand them up and they slide right in place. Which - as you can imagine - is easier said than done, but for the most part I got pretty good at it by the end of the day...A 12' tall post would be a handful to drop in a post hole. Setting 12 posts in under 4 hours sounds like a pretty rapid pace to me.
