The engine doesn't "free wheel" or anything like that, but it turns over quick enough that it would typically start (or did last fall). I've jump started it with my truck a couple times before when I left the key on accidentally, and it turned over a good bit faster, but that was with a running vehicle.
I do get "smoke" (atomized fuel and air mixture) that comes out the exhaust when it's cranking over. It's the same typical amount that I was getting when the machine ran last fall. I'm going to try to jump start it with my truck in the morning and see if a little bit more amperage, and faster cranking, will make it start. If it doesn't start, I think I have a compression problem. I have fuel, I sure should have glow plugs functioning (brand new glow plugs and voltage), so if it doesn't start with a jump start, what else could it be?
