daugen
Super Star Member
I looked up the tractor and you have 44pto hp, should be ok for that mower, though 8 feet is big.
Didn't know Mitsubishi builds Masseys in this size, most are by Iseki. Like my small MF.
I used to own a small Case IH with a 23hp Mitsubishi engine and it was the smoothest running diesel I have ever used.
But it did not like field mowing at 90 degrees, even with clean screens and a six foot mower. Kept my eye on the temp gauge and after a long pull up
an incline mowing, it would definitely creep up. But never too much.
Is your tractor overheating or is it just your trans oil that has gone bad? Or both?
You likely have a three speed trans. Are you mowing in low or medium? If you are mowing in High, that might be
an issue.
So I'll add my two cents to the something's plugged or the thermostat doesn't work.
I'd overheat too without water...
btw, welcome to TBN.
TractorData.com Massey Ferguson 1758 tractor information
an issue.
