Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    Silver Member Bwgad96's Avatar
    Join Date
    Mar 2012
    Posts
    207
    Huntingtown,MD
    Wayy to many.
    Default Gravely l8
    Hey guys so I finally got the gravely to sputter and it's gettin spark. Now I had my pops take a look and he said I have fueling issues. Honestly I'm not good at all with carbs so, where would be a good starring point? Also I'm gonna probably sell this when I repair it and play for awhile, so I'll upload a picture and what do you guys think this might be worth? Thanks
    Attached Thumbnails Attached Thumbnails Gravely l8-image-4003474957-jpg
  2. #2
    Join Date
    Oct 2010
    Posts
    231
    Dallas, TX
    Gravely
    Default Re: Gravely l8
    Time to get good with carbs.
    They aren't hard to fix. It just requires some patience and a good source of compressed air and a good blow gun.
  3. #3
    Join Date
    Mar 2012
    Posts
    207
    Huntingtown,MD
    Wayy to many.
    Default
    Ok so today I pulled the bowl off and cleaned it. It really wasn't that dirty but just to be sure I sprayed it all with carb cleaned let it sit the blew it out with compressed air. Still no luck. It will just crank and crank forever. So I thought I had the problem with magneto fixed so now I'm only getting a little tiny yellow spark. Frustrated to say the least. I now have no idea what to ever check or where to start. Thanks
  4. #4
    Join Date
    Oct 2010
    Posts
    231
    Dallas, TX
    Gravely
    Tiny spark? The magneto should produce a spark at least 3/8" long.
    Time to replace the condenser in the magneto. RIchard's (gravelyparts.com) has them.
  5. #5
    Join Date
    Mar 2012
    Posts
    207
    Huntingtown,MD
    Wayy to many.
    Default
    ok the new confenser is ordered and on the way along with new plug spark plug cable in line fuel filter air cleaned and a few other goodies haha
  6. #6
    Gold Member CTPhil's Avatar
    Join Date
    Nov 2009
    Posts
    282
    NW CT
    Wouldn't hurt to try just cleaning the points.
    When I tried to start mine after sitting, no spark. I looked close and there was white chalky stuff on the points. A little polishing with 320 grit emery cloth and it's good to go.
    Ford 2600, Ford 4100, Ford 3550, IH 560, IH 460U, 1949 Case VAC, 1951 Case VAC, assorted Gravely L Models, Gravely C10, Gravely 524, Gravely 5460...
  7. #7
    Join Date
    Oct 2010
    Posts
    231
    Dallas, TX
    Gravely
    Corroded points will indeed cause no spark at all. A weak condenser will produce a weak spark and in some cases no spark at all.
  8. #8
    Join Date
    Mar 2012
    Posts
    207
    Huntingtown,MD
    Wayy to many.
    Default
    ya i had already taken a fine file and made the points shiny so i figured that was the next step.
  9. #9
    Join Date
    Mar 2012
    Posts
    207
    Huntingtown,MD
    Wayy to many.
    Default
    ok finally got the parts in new condenser plug boot wire and boot at the top new plug and fuel filter and carb to bowl gasket. instaled everything and got big blue spark still no go gettin fuel to the bowl and spark then i rotated the timing 180 degrees and still wont start what gives?
  10. #10
    Gold Member
    Join Date
    Jan 2012
    Posts
    330
    Brookshire TEXAS
    LS R4047
    Sounds to me like you need to disassemble the carb, I dont know if it has fixed jets or needles for the main and idle. if it has needles turn them in counting the number of turns (ie 2 1/4 ) write it down ! then remove the needles and any seals ,springs, washers and spray carb cleaner through the jets. you should see spray coming into the venturie and also the float bowl area.DO NOT STICK ANY METAL OBJECT INTO THE ORFISES !! reseat the needles back to your original turns out and set the float level to even accross when holding the carb upside down.
    Good luck
Similar Threads
  1. Buying a Gravely and need help
    By Kyle333 in forum Gravely & Ariens
    Last Post: 07-13-2010, 11:14 PM
  2. Gravely L8 not starting
    By 2manyrocks in forum 2-Wheeled Tractors
    Last Post: 09-13-2009, 03:50 PM
  3. BCS or Gravely mower
    By Eric_Phillips in forum 2-Wheeled Tractors
    Last Post: 09-10-2008, 01:02 PM
  4. Comments wanted, to replace Gravely stuff
    By RalphVa in forum Gravely & Ariens
    Last Post: 12-22-2003, 08:56 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
