Results 1 to 1 of 1
  1. #1
    Join Date
    Feb 2012
    Posts
    1,676
    Holland, PA
    2012 Kubota L5740HSTC3, 1986 Case IH 255, 1986 Gravely 8199G
    Default 8199G snowblower has a problem
    which so far has not affected how it works, but I'm concerned. When it runs, the secondary blower housing moves up and down about a quarter inch, and the movement is not fast, but rather slow, like once a second. This can't be right... No weird noises, no scraping, but why the up and down motion? Something has to be bent in there or out of alignment, and I'm worried that continued use will break something. The part that goes up and down is just to the left of the chute. Anyone have a suggestion here? thanks Drew
    Attached Thumbnails Attached Thumbnails 8199G snowblower has a problem-p1000068.jpg
    2012 Kubota L5740HSTC3 with FEL and Long grapple, 1986 Case IH 255, Land Pride PD10 PHD, Land Pride RCR60 mower, Land Pride box blade and rear rake, Fred Cain subsoiler, County Line potato plow, County Line 1 bottom plow, 1986 Gravely 8199G with tow behind DR rototiller, 50" deck+40" Gravely wing mower, Gravely snowblower, Swisher 44 rough cut mower,Ariens snowblower, Echo 450-18 & 600-24, Echo PPT280, 2006 JD LX280, , 1968 Cub Cadet 125, Husky-Speeco 35 ton splitter 2012 Suburban 2500
Similar Threads
  1. Repowering 8199G
    By daugen in forum Gravely & Ariens
    Last Post: 02-08-2013, 05:28 AM
  2. snowblower pto problem
    By Troy Falk in forum Parts/Repairs
    Last Post: 02-01-2012, 09:24 PM
  3. vibration problem with snowblower
    By PHS79 in forum Attachments
    Last Post: 11-17-2010, 06:18 PM
  4. Snowblower snowblower hookup problem
    By karman 4564 in forum Attachments
    Last Post: 12-09-2007, 10:44 PM
  5. B3030 SNOWBLOWER PROBLEM ??????
    By botamoose in forum Kubota Owning/Operating
    Last Post: 02-02-2007, 05:07 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
