Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Join Date
    Dec 2007
    Posts
    128
    Thumb of Michigan
    Kubota L3130DT-F
    Default Re: New member gravely L8 walk behind
    With an L8 and strap pull start, will it spin any easier with synthetic oil in cold (30F) temps. I currently use the 10W30.
    Opinions?
    Kubota L3130DT-F, LA513 FEL, 7'Backblade, 5' TSC Box blade, Woods RM-301 Finish mower + 1975 Gravely 7.6HP with goodies
    "Diagnosis is 80% of the cure." ~ Dr. M. A. Balcerski M.D.
  2. #12
    Veteran Member Carl_NH's Avatar
    Join Date
    Apr 2002
    Posts
    2,181
    Coastal NH
    01 Kubota B21TLB, 2010 Ferris 52" ZTR, Cub Cadet 1811, Gravely Super8
    Default
    I really don't think different oil will help much - that's a big piston and flywheel mass to get going.
    Most important good fuel and good spark - do you need to blow snow?
    My experience is these older machines don't like cold as they get old - the gas too is different today than the leaded they grew up with.
    Kubota B21TLB, Ferris IS2000, Cub Cadet 1811
  3. #13
    Join Date
    Dec 2007
    Posts
    128
    Thumb of Michigan
    Kubota L3130DT-F
    Snow blowing is required. The back blade on the kubota will only push the snow from the 300' driveway and I need to get rid of a lot, with more on the way this week. The compression, spark and gas work together great! Just seems like the oil is so thick I need to warm up the block to get it going. The cylinder was rebuilt by Richard's and has given the engine new life. I hope to get another 30 years out of it (or at least my son will). BTW, the snow blower is a beast with an impeller that may be heavier than some new big box store entire machines. With the spark adjusted properly all I need to do is get the "snap" and the engine fires up on the second pull. Probably the best investment I've ever made, (other than my wife). Total was $1.122.73 back in 1975 which was a small fortune back then. It has plowed the garden in the Spring, cut brush in the Summer and blown a mountain of snow in the Winters ever since.
  4. #14
    Elite Member Industrial Toys's Avatar
    Join Date
    Feb 2008
    Posts
    4,319
    Ontario Canada
    Kubota R510 Wheel Loader + Cab and backhoe, JD 6200 Open Station, Cushman 6150, 4x4, ten foot 56 hp Kubota diesel hydraulic wing mower, Steiner 430 Diesel Max, Kawasaki Diesel Mule, JD 4x2 Electric Gator
    New member gravely L8 walk behind-dsc01393-jpg
    I used this Gravely for years. A neighbour always thought a helicopter was coming on account of the single cylinder Kohler. I had to have those laser cut plates put on the back, plus more that were later welded into a single pack that weighed around 200 pounds just to balance the thing, otherwise you could not lift the blower. But man tht blower would blow a hundred feet! But awkward as ****!
    I had a bush hog. Cut the front out of it with the plasma cutter to better cut brush and the odd crowd control assignment. Then I hit one stone and shattered a shaft in the mower resigning it to the scrap pile!
    The finishing mower gave the best cut of any mower I have ever seen. Used dual wheels as I have a large hill behind my house. I had a sulky, with steering wheel and steerable wheels. It was a real hoot like an amusement park ride when you turned, but quite dangerous actually and I never did use it. You would hit a slight dip, and those handles would come down so quick, it wasn't even funny! You had better not have your legs together at the time!
    Finally got rid of the whole thing in favour of a Steiner, but I am sure gonna miss the excercise running after that thing!
  5. #15
    Join Date
    Feb 2008
    Posts
    4,319
    Ontario Canada
    New member gravely L8 walk behind-dsc01202-jpg
    Found this pic of when I took the machine to a GFs cottage to cut the grass for her Mother! Used the Sulky, cause I figured I might stand a better chance against the Rattle Snakes! lol
  6. #16
    Join Date
    Dec 2007
    Posts
    128
    Thumb of Michigan
    Kubota L3130DT-F
    Quote Originally Posted by cleaveunto View Post
    Thankyou for the welcome.
    Now down to business.I have a rotary cultivator attachment but no tines.I would like to have the rotary plow set up,is it possible to add the shaft and blades to the rotary cultivator ?Much thanks in advance.
    I think the answer depends on the age of the cultivator. On some of the older (1970's) units the cultivator was an attachment to the rotary plow attachment. Indeed, if you have one of these then yes, removing the tiller attachment and inserting the hex shaft and blades makes it into a rotary plow. I do this every Spring to "plow" the garden and then convert to the tiller to run between the rows after planting.
    Bruce
  7. #17
    Bronze Member Den1952's Avatar
    Join Date
    Feb 2012
    Posts
    83
    Weyauwega Wi
    InternationalHarvestor tlh
    I am new to gravely also, i got one with several attachments. the one mounted is like yours here (Brian) and i thought it was a brush cutter. maybe it is...
    today i ran it headfirst into some marsh grass, and the underside of the deck plugs up. that is when i first noticed there are no open port for a grass discharge.
    apparently on a lawn it doesnt need the opening.?
    so, is that attachment shown a brush cutter or a lawn mowing deck?
    mine does have a super thick blade in there, that is why i thought it was a brush cutter.
    not sure what model mine is , I think it said 5200 on the hood.
    Den
  8. #18
    Join Date
    Nov 2013
    Posts
    1,077
    Southwest Ohio
    2005 JD 3520
    Den - go ahead and post pics of the implement(s) you're asking questions about. That would help a LOT!
  9. #19
    Join Date
    Feb 2012
    Posts
    83
    Weyauwega Wi
    ok, i will be back about noon, and post some.
    meantime, it looks like the mower on brians photo , of this posting. way back at the beginning.
  10. #20
    Join Date
    Apr 2002
    Posts
    2,181
    Coastal NH
    Hi Den - I posted the picture of my Gravely L-8 Convertible (second post) and this is the brush cutter attachment - its round - the gravely mower is more traditional rectangular shape with several blades.
    There is no discharge on the brush cutter - it is meant to chew things up.
    The brush cutter has two thicknesses of blades - a real heavy one almost 1/2" thick, then a regular duty 3/8" thick. The brush cutter does cut grass just fine, but in stringy marsh clumps will wrap around the shaft unless you ease into it slowly. I think you found this out.
Similar Threads
  1. Redoing ignition on Gravely walk behind
    By MMist in forum 2-Wheeled Tractors
    Last Post: 06-10-2013, 04:38 PM
  2. Advice on Gravely walk behinds wanted
    By lefty0491 in forum Gravely & Ariens
    Last Post: 05-29-2013, 11:11 PM
  3. new member Gravely 816
    By willgravely816 in forum New Member Introductions
    Last Post: 05-17-2011, 07:27 PM
  4. Checking out a Gravely walk-behind...Advice?
    By PatasColo in forum Gravely & Ariens
    Last Post: 04-11-2011, 07:54 PM
  5. my homemade gravely walk behind
    By bobcat fan in forum Gravely & Ariens
    Last Post: 02-16-2010, 06:45 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
