Picked up a Hinomoto E14 the other day thinking since it was made for MF parts wouldn't be a problem. Guess I was wrong on both counts as parts are scarce and I found out this was not the model made for MF. Still a great running little tractor and I am satisfied with the purchase so far. Has 690 hours, good sheet metal, no leaks or excessive smoke, and I only paid $1500 for it and a 4' blade and bushhog. Only complaint so far is it is very hard to start when cold. Gonna pull the glowplugs and make sure they are both working.
I have been looking for a manual for this tractor but have had no luck, so figured I would ask a couple questions here and see if anyone could answer them.
1 What is the foot operated lever on the back right side of tractor? Posted 2 pictures of it. Im thinking diff lock maybe?
2 In the picture of the dash what does the black swithch on the left do? It appears to be a 3 position switch, off and headlights im guessing, not sure of other position. The right black switch appears to work the rear amber turn signal flashers.
3 Does anyone have a wiring diagram they could post or link to?
4 Anyone know where to get replacement key, or possibly replacement ignition switch? Key doesnt fit but will work it if you jiggle it. I dont jiggle it right and keep bending it. May just replace with master toggle switch and 2 pushbuttons for starter and glowplugs.
Thats all for now, but im sure I will have more. :confused3:
