Hi all,
Our Hinimoto E2304 ran fine for several years. Recently I noticed that when I was mowing it tended to die, so I had to give an extra swing on the gas throttle to keep it running. I decided to check some maintenance points myself.
I let the old oil out, changed the oil filter, looked at the fuel filter, it looked very contaminated. I screwed the bulb of and saw immediately that there was a serious amount of dirt on top of it. I threw away the old filter and got a new one. I reassembled everything, bled the fuel lines and it started again.
At this point I was very happy because I'm no mechanic at all. But that happiness turned into a little frustration when I noticed that there was a strange noise hearable through the exhaust (sort like the really old tractors, kinda "hollow") and that it still has the intention to die when running idle. It seems like there is also some loss in power.
You can now hear the pistons through the exhaust pipe, that wasn't noticeable before. I first thought that there was something wrong with the air intake. I took the air filter out and blew it clean, I also blew the radiator clean. No progress.
I checked if all cilinders were running by turning the fuel lines a little loose. The tractor was dieing when the screws were turned loose, little diesel came out so I think all 3 cilinders are working.
Here is a sound fragment of the tractor running.
Can anybody tell me what is wrong ?
Maybe it would be an idea to clean out the hose that runs to the fuel filter, does anyone knows if there is a closing valve at the bottom of the fuel tank ? I can not seem to find one on my tractor.
Greetings
Greetings
