Monroematic Auto 3 point controller
   / Monroematic Auto 3 point controller
No problem. Thanks for the attempt though.
I can get mine in and out of auto mode okay. I'm trying to figure out to set the "pre-set". I think there is a way to use the lever on the steering column to "pop" the 3 point hitch to a preset height and then lower it again by actuating the lever again. That would be nice for when I reach the end of the yard while mowing and I turn around in the field. It would also be beneficial while using the back blade.
The other thing I want to be able to do is use the conventional lever to raise and lower the 3 point as opposed to the toggle switch.
Thanks again.
   / Monroematic Auto 3 point controller #22
   / Monroematic Auto 3 point controller #23
Hi, could you explain me the function of the monroematic control please? thank you
Pab
A friend of mines cousin is married to a Japanese lady. We took pictures of my controls including to 2 green lights and mailed them to her last Saturday to translate. When I get the info back I'll be glad to share it with you.
Eugene
Brush Bandit 200UC Towable Brush Chipper (A52377)
Brush Bandit 200UC...
2010 Lincoln MKS (A50324)
2010 Lincoln MKS...
UNUSED LANDHONOR LHR-EPC40 PLASMA CUTTER (A54757)
UNUSED LANDHONOR...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2014 FREIGHTLINER...
2010 KMC 3376 Peanut Combine (A55301)
2010 KMC 3376...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
