Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 38
  1. #21
    EFC
    EFC is offline
    Veteran Member EFC's Avatar
    Join Date
    Dec 2001
    Posts
    1,149
    Benton City, Washington
    Enough
    Default Re: Tell me about Hinomoto tractors
    Hinomoto was bought by Hitachi. The rumor that Kubota bought them came during a time when Hinomtos were just rebadged Kubotas specifically the NX series. I like the N and C series but have discontinued selling any E models due to the aluminum bell housings and on some models the unsupported cone pivot front axels. Models without the lower brace on the cone cannot handle a loader.
    Buck
    "People believe what they want to believe, reality be dammed"
    "You only fear from people what you would willingly do to them"
  2. #22
    New Member
    Join Date
    Sep 2008
    Posts
    1
    Quote Originally Posted by buppy69 View Post
    I agree and mine will probably be one of them. But I expect in 10 years I'll be too old to play around with them anyway. Last winter I was trying to switvh to Yanmar. Looked for an F or FX24D. Couldn't find one and then the N239 came up on ebay. The rest is history and now I'm back into Hinomotos hot and heavy. I've got an E2604 and an E2804 coming from Japan with a delivery date of 10/28.
    Eugene
    PS Wayne, it's a funny thing. "Lawn Ornaments" is what my wife has called my tractors from the start.
    Hi Eugene:
    I am about of buying de E 2604 model. Iエve never had a minitractor before, then i ask for your advice. How it went this tractor with you?. Would you recomend me to buy it?. Are parts available to buy?.
    Well, thanks a lot to read my note, hoping to get your answer a big hand from Bolivia.
    Homer
  3. #23
    Platinum Member buppy69's Avatar
    Join Date
    Mar 2002
    Posts
    788
    Western NC
    Hinomoto E2804, Hinomoto N239,
    Homer
    The E2604 is a good tractor. Nothing has happened to mine
    , yet. I put a Bush Hog loader on it and work it hard. Parts are available but you have to know where to look . They're not easy to find, sometimes. So far mine hasn't needed anything, so I don't worry about the parts issue unless it comes up. Hope this helps.
    Eugene
  4. #24
    New Member
    Join Date
    Feb 2010
    Posts
    1
    E 14 hinomoto, lift works till it gets warm then drops. After it cools down it works for an hour or so then quits again. Is there a filter in this system, if so where. Is the pump going out? Any thoughts would be appretiated.
  5. #25
    Member
    Join Date
    Jul 2009
    Posts
    37
    New England
    1968 Cub Cadet 125 Hydrostatic, 1974 Cub Cadet 128, 1961 Hinomoto E-21
    Quote Originally Posted by keny walker View Post
    I have a Hinomoto E-21 (The E-14 and the E-21 are from the same product line) and On my machine, there is a fuel filter mounted right under the tank on the left side of the machine (from the operator's station)
  6. #26
    Member
    Join Date
    Apr 2010
    Posts
    25
    Why stay away from the 2cyl engines?
    Found a 2cyl with 120hrs, box scrape and 48" finish mower for 3000
  7. #27
    Join Date
    Apr 2000
    Posts
    1,513
    Dixon, Il
    They are from the late 70's 7 engine partsare becoming obsolete. Don't believe the 120 hours. It is probably a Viet rebuild with the hour meter turned back.
  8. #28
    New Member
    Join Date
    Jun 2010
    Posts
    5
    Can anyone tell me what model of hinimoto this is and the pros and cons of it. Came up for sale cheap. Thinking of looking at it. What is the common problems with this model. Thanks opps the picture did not attach. i'll try again
  9. #29
    New Member
    Join Date
    Jun 2010
    Posts
    5
    Can anyone tell me what model of hinimoto this is and the pros and cons of it. Came up for sale cheap. Thinking of looking at it. What is the common problems with this model. ThanksTell me about Hinomoto tractors-hinimoto.jpg
  10. #30
    Join Date
    Apr 2002
    Posts
    2,086
    SW Ohio
    yanmar
    Quote Originally Posted by 12valve View Post
    t. What is the common problems with this model. ThanksClick image for larger version.
    Parts....regardless of model.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
