Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520
Here are the two coupler mounting panels I cut from stainless, before any bending or anything. The couplers have a snap ring groove on them, which holds them in a hole, if you can get the hole the right size.
Another pic shows one coupler snap ringed in there.
And here a couple pics showing the panels mounted in place.
That's about it. I sent for a few more hoses and fittings to try making some routings better. And I still need to plumb to the remote coupler panels with hoses and T fittings, but none of that will be picture-worthy. Later I will plumb on the loader frame too, to carry this circuit to the loader frame cross-member, where I will have two more couplers, to allow powering my grapple cylinder. Thats all pretty boring hose-routing stuff though. So I am calling this project complete. I used the tractor for a bit of loader work this weekend and the auxillary valve location is good I feel. It is not in the way for normal operations, yet it is in nice position when you want to access it. I may add a small orifice restrictor to the sidelink circuit, as it seems too fast now. So, this thread is a wrap. Enjoy. Hopefully it can be found with a quick search when needed in the future.
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #34
Very nice job Jim. Looks like it was factory installed! :cool:
I would like to add rear remotes to my Kubota 3010 at some point. Factory parts are $800 for each remote, which seem very high to me (of course I'm not seeing the work involved for their parts).
Couple of questions -
What did the project cost? A breakdown of major items & their costs would be helpful, if you would not mind. (valve, hoses, cylinders, etc).
Any idea on what the factory parts, or dealer installation would have cost?
And a really dumb question, which shows my limited knowledge of hydraulics, - If I wanted to do a similar project for my Kubota, is there a component that I would need to have on my tractor prior to starting, or is what you have done a replacement for the factory rear remotes?
Many thanks for documenting this. I have learned alot from your work here.
Mike
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #35
jimgerken said:
A set screw, John Deere part number PT13744, must be threaded into the block, inside the "front facing" port.
Just curious - How did you learn to block this port - Why do you block this port?
thanks
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #36
thanks
I can answer this, as I did the same thing on my 4110, the screw stops the fluid from flowing "through" the block, and directs it to the OUT port.
Yea, what Kenny said. The set screw changes the flow so it has to flow out one port and back in the other. In other words, if you did the set screw, put it all back together, and did not add the auxillary valve which allows the fluid to flow thru and return, your loader wouldnt work. The open center hydraulics depends on continuous flow thru all valves.
Actually I learned this trick right here on TBN. I am very sorry I cannot give due credit to the guy who told me this first. It was in 2001, when I was doing my 4100. I happened to ask the right question and was taught this.
Once you understand what to do, you realize that the John Deere Power Beyond kit contains a block with a setscrew in it already. And fittings atttached. And hoses. If you buy the hoses you really want, and now that you know the fittings are SAE 6 threads so you buy those two $5 fittings, and you get the JD part setscrew for $1.38, you are all set and just saved over $200. The block itself is identical, in my experience.
Mike
Cost, from memory:
JD setscrew $1.38
two right angle SAE 6 fittings about $10.00
valve, three-spool Prince sectional $280.00
Top link cylinder already preped $179.00
sidelink cylinder to be mod'ed $135.00
hoses fittings couplers about $300.00
labor for fabrication & plumbing, about 20 hours
metal for brackets and plates about $15.00
I don't know what JD would get for this. I doubt that you can get three additional spools for the 2520. There might be one available. I am guessing they'd want about $650 for that one, judging by the price on the stock Power Beyond kit.
As far as your Kubota, I don't know what the details of your hydraulic system is, but the starting point is to get the hydraulic flow out to the valve of your choice. So , whatever they call it, you need the equivalvent of the Power Beyond kit, or know how to tap into the series flow as I described. There are many good choices for valves, just make sure to get one that is rated for your tractor's hydraulic flow in gallons per minute. Finding space to mount the valve is a battle on these small tractors. My "forward controls" idea can allow you to place the valve back further and still control it well. Ask questions here on TBN, with nice specific thread title(s). Someone has done it before, most likely. Good luck!
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #39
Thanks again for sharing. Most beneficial.
Archived...
:tiphat:
   / Adding Power Beyond, 3-spool hydraulic valve, and T-n-T to a JD 2520 #40
If in a few weeks, you decide you don't like what you made and want to sell....
I know that is not going to happen, very nice work and write up, Thanks for sharing. JC
2017 GMC Savana (A53314)
2017 GMC Savana...
2014 Ag Spray Schaben Sidedresser (A53472)
2014 Ag Spray...
Giyi Hydraulic Breaker (A53316)
Giyi Hydraulic...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A55787)
2023 Caterpillar...
2013 Jeep Patriot Sport 4WD SUV (A55758)
2013 Jeep Patriot...
2018 John Deere 30G Mini Excavator (A52377)
2018 John Deere...
