cgraham
My contractor friend proposes to cut off a damaged fitting and welding on another to the sleeve of the cylinder controlling bucket curl on a compace backhoe. He has offered to do it as he has a well-equipped shop and is very competent. The cylinder will be removed, and so, drained.
I know that standard practice is to disassemble a cylinder before welding on it, and cleaning before and after.
He says there is no need to disassemble the cylinder for this weld. Just extending the cylinder will pull all the internals away from the work area. That raises a question about cleaning. He is not concerned that any metal particles of significant size will fall into the cylinder (using a rotary cutter).
So what is the reason for cleaning BEFORE welding? Is it fear of baking oil on the cylinder? I'm thinking that the mass of metal will dissipate heat from the relatively small weld, and thus this may not be a problem.
Thanks for views on this overall approach.
Charlie
Charlie
