Reservoir questions - how big/adding second
   / Reservoir questions - how big/adding second #1
lhfarm
Central Indiana
NH TC40DA
I have a small dump trailer with a 24" x 4" cylinder. Works great using the hydraulics on my TC40DA. But I want to pull and dump the trailer with my Jeep and Cub Lo-Boy, so am trying to build a portable 12V pump unit. The attached picture shows the pump unit I have been trying to use. The reservoir is too small. The pump will lift the bed quickly, until the reservior is emptied.
Is there a simple way to calculate the size reservoir I need? Since the unit I have (and would like to use to save some $$$) is a single unit, can I rig a second tank to set on top? It would drain into the top of the current reservoir and the return hose plumbed into the top.
Or should I give up on this pump and buy a new rig?
Thanks
   / Reservoir questions - how big/adding second #2
The reservoir size would have to be at a minimum the volume of your hydraulic cylinder when extended (ie. extension length x 3.14 x square(piston diameter/2)).
for a 4" cylinder with a 24" stroke, this would be:
24 x 3.14 x (4/2) x (4/2) = 301.4 cu in. or 1.3 gal.
I think you need a 1.5 to 2 gallon reservoir for that size cylinder.
Hope this helps.
Hope this helps.
That does help - thanks! I'll do some measuring and see if I can determine how big the current tank is - I'm thinking less than a gallon. And I'll see if I can find an auxillary tank.
Wacker Neuson RTSC3 (A47477)
Wacker Neuson...
Giyi 78" Grapple (A53316)
Giyi 78" Grapple...
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
Oil Tank (A50775)
Oil Tank (A50775)
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
