Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Sep 2007
    Posts
    6
    Louisiana
    1969 Ford Tractor 2000 gas
    Default 69 Ford Model 2000 gas
    I have 1969 ford 2000 3cylinder gas burner I was playing with what I beleive was the draft lever(directly under seat on right)I think it was in a vertical position. I pushed it down it was very hard, now when I put it back up to vertical position I cannot control the up and down with my lift lever. Everything before was working fine it sounded like the hydraulic was making a noise/whining so I checked the fill plug and nothing came out I bought hydraulic oil and filled till it came out the fill plug. Then I started having problems. NEED Help thanks in advance
    Since then I changed the hydraulic fluid still same thing. I put the bush hog up about a foot yesterday and it stayed utntil I put it down today.
  2. #2
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: 69 Ford Model 2000 gas
    If your draft linkage was real hard to move, I wonder if you don't have some corrosion or rusty springs / linkages.
    Hit the NH site and look at the exploded diagram of the lift cover for that model.. you'll see what i mean.
    If you have a parts manual, it will be listed in there as well... Page 88 figure 05A01
    Might be something that moved then didn't move back..
    Soundguy
  3. #3
    New Member
    Join Date
    Sep 2007
    Posts
    6
    Louisiana
    Thanks I need all the help I can get
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
