bill333
I am going to get a Kubota L3240 or L3540. I want to add the following options/implements:
-- FEL
-- TNT
-- rear blade
-- maybe a front blade for snow plowing (especially if I can get a QA). I do not want a blower.
--maybe a post hole digger
I want as much (preferably 100%) of all the hydraulics/valves/remotes installed by the dealer while I壇 love to learn about it sometime, I must confess that after hours and hours of reading the posts here I still don稚 understand the entire hydraulic thing. And while I have great respect for all of those that do their own options add ons, I have so little time that the amount of money that might be saved is not enough to justify figuring everything out.
So here are my questions, which I realize apply mostly to Kubotas, but most are general hydraulic issues for the 'hydraulic challenged' (me):
Is the 禅hird Function Valve option (L2225) for the Grand L series what I need to run a grapple? If so, do I need anything else, or does this include some kind of switch/button for the loader control joystick?
I assume I need 2 rear remotes for a Top-N-Tilt kit?
Should I get double acting or FD Float detent for the rear remotes?? Am I correct in assuming that a float will help me plow snow/grade with the rear blade?
Do Kubota hydraulics come with check valves? If not do I need them, and how should I order them?
thanks for any input.
-- FEL
-- TNT
-- rear blade
