detel
Member
I have a '93 Ford 4630 dsl., 2 wheel dr. that I was bushhoggen with and it felt like I somehow hiit the lever and shut the pto off because the mower started slowing down. I check the lever and it was still in gear so I went to raise the bushhog to take it to the barn but none of the hydraulics work. I check th fluid and it was low so I brought it back to full but still nothing. The pto shaft turns real slow but there is no engaging it with the lever. Any ideas of what or where I might look for the problem? Is there some kind of Knock off switch for the pto to shut down if you hit something? Any help would be appreciated.
Thanks
Michael
Thanks
Michael
