#1 (permalink) |
I'm doing a favor for a friend here. For the tractor in the pics below, I need to add rear hydraulics to work a manure spreader and some haying equipment. I'm told there used to be a FEL on this machine. That's where the valve came from. He wants to work his equipment from this valve. Am I right in assuming that the pressure line would be from the qd underneath the floorboard? If so, is that where I should hook the return to? I'm guessing that the hydraulics from this line does power the 3 point hitch also. And, in the third pic, there is a steel line going to a qd. What would that be for? Any help would be appreciated.
Thanks, Andy.
__________________
Knowing is not enough, you must apply. Willing is not enough, you must do. Bruce Lee |
#2 (permalink) | |||
here are my guesses, this info based off of working on my dads old MF Industrial 35, therefor it may or may not be valid for a JD.
Quote:
Quote:
also what does the steel line above the QD do??? looks too small to be a intake for the pump, it is for power brakes??? Quote:
HTH Aaron Z
__________________
There is no such thing as an underestimate of average intelligence. - Henry Adams |
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
