I have a 460 utility and I am having lift problems. The other day I was moving some dirt with the loader. After about 8 loads I went into the pile, pushed up on the lever and nothing. Backed out and the list dropped about 8-10 inches. I tried to lift it again and it dropped again and stopped. Let the tractor idle for a few seconds and it went up slow and whined. The power steer started to whine also and was harder to steer.
I am going to replace the filter etc etc? so what do you think the problem is????? Pump??? Something in the spools????
I am going to put a pressure gauge on it first. Planning on hooking to the quick connect after i disconnect all the cylinders. I assume this would be ok?
Thanks for the help!!
