3rd SCV install questions
   / 3rd SCV install questions #1
JB4310
Super Member
Central CT
J.D. 4310 E-hydro
I just got a 3rd scv kit today for my JD 4310, and have a couple of questions, I only ordered the rear remotes for now as I'm trying to mount a western truck plow to my 3PT and would like to power angle it, I'll also be looking into a hyd top link for other applications.
The kit is pretty simple, only 2 steel lines with quick couplers and a lever. here are my questions,
1. when I open the boss plugs on the valve will much fluid flow out? do I need to drain anything?
2. I'm a little confused on the straight adaptors, though I think I figured that out, there are 2 ORFS 8-8 and 2 ORFS 8-m18. all 4 have a common size thread on one side which matches the steel lines but on the other side of the adaptor 2 are one size and 2 are a little smaller and have a little shoulder between the threads and the hex part, I believe that's the side that goes into the valve?
3. Do I use teflon tape on any of these fittings or are they designed to seal with just the o-rings?
4. lastly, there are torque specs but how would I use my ratchet/socket type torque wrench on the steel lines, how tight should I make them with just an open end wrench?
thanks, JB.
here are a few pics one shows the 2 adapters side by side
looks like I'm going in alone, I really want to do this today, think I got most of this figured out. have the wheel and fender off now and ready to pull the plugs. I don't see teflon on any other fittings so I assume I should not use it, the torque specs are my biggest concern, I'll just bring them in pretty tight for now, I do have a tendency to over tighten fasteners.
   / 3rd SCV install questions #3
Very little fluid will drip out, no need to drain.
Not sure I understand this?
No tape! The O-ring will seal the fotting.
thanks, JB.
A good "snug" will do. There is no need to bear down on them
   / 3rd SCV install questions #4
Sometimes it takes more than 2 hours to get a useful reply:D
Thanks for the reply Kenny, my first post was last night but I know that's still being a little ambitious/impatient, anyway all went pretty good, I'll have about 8 hours into this but if I had to do it again it would take half the time. I did this all by myself, if I had a helper it would have been easier.
The seat was a pain in the neck and the worst part was placing the lines since I have the power beyond and the heavy steel side plates to hang the back hoe on, had to remove one of the PBY lines even then it was a trick to get them in there, the plumbing all went smoothly, good thing the bends are perfect and the surfaces matched up just right, I did snug them firmly but not crazy tight.
Still have to install the seat pan and seat so I couldn't check for leaks yet
I've heard that you shouldn't move the lever if nothing is attached to the remotes, is that true? now I just need some male adaptors for those quick couplers and some hoses to the plow cylinders, do you have a recommendation on the hose rating/type.
Thanks again, JB.
   / 3rd SCV install questions #6
ooppss...I see know that it was in the AM...sorry to bust your chops-I could not get online this morning.
It's OK in very short burst's to test for leaks. Hold the lever in each direction for 1 or 2 seconds at a time-the tractor will bog down, that's a good sign
Just regular 1/4", 2-wire, 4000psi rated hose, do you have a hydraulic shop in your area?
kennyd Just regular 1/4" said:
WE use to have a shop very close but they are gone, I'm sure we have one around here I just haven't needed anything from them in a long time since my snow plowing days, I'll ask around.
So 2 wire, 1/4", 400psi, just measure what I need and have them install a standard threaded fitting? that I can screw the male adaptor for the remotes on and the threaded fitting on the plow cylinders.
I'll get the large male adaptor from the JD dealer so I'm sure it matches the new remotes, are they metric or sae? I'll probably bring them to the hyd shop so they can fit them.
   / 3rd SCV install questions #8
The male QD nipples are either NPT or ORFS. Some NAPA auto parts stores make hoses, as well as some tractor dealers... also look in the phone book under "hydraulics"
Got the lines made up at the Deer dealer, the nipples are the o-ring type. 2 four footers of 5000 psi with hd Eaton crimps with the nipples and threaded swivel 90's, took them 5 minutes, cost $110.
Good thing no leaks, only problem is the plow angles very fast, about 2 seconds at idle from one extreme angle to the other and only about 1 second!! at 2200 rpm's. there is a strong spring resistance to the lever movement so it's fairly easy to control/feather it but is there another way to slow it down? I've heard about a metering disc that goes in line somewhere to limit fluid flow?
Thanks, JB.
   / 3rd SCV install questions #10
You can slow it down with flow restrictors, basically little washers with a tiny hole in them to limit the amount of fluid that passes through. There are also adjustable ones that cost about $30 each.
4ft Mini Skid Quick Attach Rotary Cutter (A56436)
4ft Mini Skid...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
2025 Safety Basket Forklift Attachment (A59228)
2025 Safety Basket...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
