Results 1 to 10 of 10
  1. #1
    Platinum Member jgrreed's Avatar
    Join Date
    Jun 2008
    Posts
    787
    Regina, Saskatchewan
    JD 4720
    Default How does this valve work??
    Hi,
    Does anyone know how this valve works?? When they say cables, do they mean cables that run to the valve block and physically pull on something on the block, or electronic cables that actuate the valve??
    Burden Sales Surplus Center Item Detail
    Has anyone built an electronically controlled system like on the new CAT/Bobcat/ASV skid steers?? I was thinking that it'd make plumbing a lot easier because you'd only need to run wire, not pipe. Likely more $$ though....
    I'm just brainstorming for ways to add a 3rd SCV for a grapple on my FEL, and 2 more SCV's on the rear for TnT.
    Thanks,
    -Jer.
    ________
    2005 JD 4720, 400x loader with bucket, bale spear, pallet forks, Markham LD grapple, Markham snow blade, Schulte BX 74 snowblower, Caroni 1900 flail, 8' Aerway, 3rd SCV at rear, hydraulic toplink from CCM, LED lights front and back, added EH hydro circuits, big pile of 3pt implements.
    Wish List:
    PTO hydraulic pump to run custom fab'd hydraulic snowblower, broom, weed wacker, or PHD. Side link from MtnView Ranch....
  2. #2
    Elite Member
    Join Date
    Jul 2006
    Posts
    4,409
    Northwest, WA
    Default Re: How does this valve work??
    Quote Originally Posted by jgrreed View Post
    They mean 'mechanical' type cables. They "physically pull on something on the block".
    ::Sent from a standard desktop keyboard::
    My Photobucket
  3. #3
    Join Date
    Aug 2007
    Posts
    2,352
    Wayne County Pa.
    Massey Ferguson model 85, Allis-Chalmers WD-45
    I put one like this on a Cat skid steer. Burden Sales Surplus Center Item Detail
    It was a pretty neat setup. Made life easy.
    Knowing is not enough, you must apply.
    Willing is not enough, you must do.
    Bruce Lee
  4. #4
    Join Date
    Jun 2008
    Posts
    787
    JD 4720
    Quote Originally Posted by Wayne County Hose View Post
    How do you control that block?? Is it via a 4 way joystick plus a button/switch, or is that a diverter/selector type valve where you choose which port of the 3 ports you are controlling with the stick???
    -J.
    ________
    Wish List:
  5. #5
    Join Date
    Jun 2008
    Posts
    787
    JD 4720
    I was thinking something like the one below. I'll admit I have no idea what one of these costs, but it does look like it'd be an awesome control device and a fun project. Something like this would be a lot easier to mount in an ergonomic spot than a mechanical valve would be. It would look good too.
    Would the output from a stick like this be compatible with valves that are available from surplus center?? Are there valves available that allow for differential input to the different axis' (ie light touch vs. full force) ??
    I'm thinking that if possible I'd convert my FEL controls to a stick like this with a rocker switch on it to run a 3rd FEL SCV. I'd then use the current factory 4 way FEL SCV to control 2 new rear SCV's, plus I'd have the 3rd rear SCV controlled by the current single stick.
    At the end of it all I'd have 3 front, and 3 rear scv's, available all the time with no selector or diverter switches, which'd be nice. The JD diverter costs $2000, so if it's anywhere near that cost, I'd do it.
    Lemme know what you guys think, if I'm crazy or not...... I'm no ag or hydraulic engineer (but my brother and his girlfriend both are!!!) but if the stick's output mates easily with certain valves, it wouldn't be all that hard, I don't think??...
    Appreciate your opinions on my madness.....
    -Jer.
    Attached Thumbnails Attached Thumbnails How does this valve work??-g3universal-jpg
    ________
    Wish List:
  6. #6
    Platinum Member yankeerider's Avatar
    Join Date
    May 2007
    Posts
    570
    North Central Connecticut
    Deere 755
    Andy-
    Is the check valve on the 3rd circuit easily removed? It seems to me that would have to come out to use it with a double acting cylinder.
    Jerry
    JD 755 w/70 loader, 60" MMM, LandPride FDR2560, Artillian Forks, Brush Bandit chipper, Woods RB60 blade, 48" KKII tiller, DR LeafVac
    Gator HPX 4x4 Gas,Cat 303c CR mini-ex
  7. #7
    New Member
    Join Date
    Jun 2008
    Posts
    22
    Kubota L39
    Another known source of multifunction control grips is Scorpion Technologies (Scorpion Technologies LTD.). They have products specifically targeted at the tractor market.
    - Terry
    Kubota L39 TLB, 6' Land Pride rotary cutter, 66' Land Pride box scraper, Woods/Alitec pallet forks, Kubota ballast box, 6' Land Pride tiller, ANBO 6' grapple rake
  8. #8
    Join Date
    Aug 2007
    Posts
    2,352
    Wayne County Pa.
    Quote Originally Posted by yankeerider View Post
    Andy-
    Aww shoot, sorry, I forgot to respond before.
    I do forget, but I think the check valve can be removed and a JIC plug with the correct ORB o-ring installed on it will be okay. Or, an ORB plug but they're more expensive.
    Bruce Lee
  9. #9
    Join Date
    Aug 2007
    Posts
    2,352
    Wayne County Pa.
    -J.
    To tell you the truth, I forget. Jeez, sorry, I must sound like Bill Clinton right about now. I just installed the valve and ran the hoses, nothing else really. The machine owner ran the wiring. I think all the wiring was already there. Wish I could help more.
    Bruce Lee
  10. #10
    Veteran Member CCWKen's Avatar
    Join Date
    Mar 2005
    Posts
    1,197
    South Texas, USA
    Ford-3910, JD-420C, Kenbota-Custom, IH-2606
    Yes, the remote in your link uses mechanical cables to activate the valves. Remotes are handy if you're tight on space around the cockpit/cab. The handle can be mounted in a convenient location and the valve assembly is mounted elsewhere. In this case, within reach of the 78" cables. Keep in mind that hydraulics must still be run to/from the valve and the mechanical cables must run from the valve to the handle.
    The problem with most electric valves is that they are either open or closed. You can't feather the valve so cylinders react to the full flow of the pump. Careful planning and sizing of the cylinders and pump are necessary or you can't control the speed. This is why many of the electric valves have restricters--To cut down on flow and thus slow cylinder movement. Still limited control though.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
