Eric_Phillips
I just got a post driver and I am trying to figure out how to plumb it to the tractor. This is on a FarmTrac 270DTC. There is a distribution block that has two lines in from the tractor. There is one line to the steering and two lines to the loader valve. One line goes to the pressure in and the other to the PBY port. On the loader valve there are four ports going to and from the loader cylinders. There is a return line leaving and going back to the sump. There also seems to be two unused ports. So are the two unused ports a supply and return for the PBY? Since I currently have no plans to add a grapple or such to the loader but would like to get some rear remotes to attach the post driver and hopefully a TnT can I disconnect the line from the distribution block that goes to the PBY port on the loader valve and run that back to the rear for the remotes? Can I then put a T in the return line from the loader valve for the return from the rear remotes?
